Old 07-16-2011, 10:37 PM   #1
mlevario99
Exclamation 5.3 or 6.0 into a 82 GMC 4x4
I am going to be doing a engine swap, the 82 4x4 GMC has the 6.2 right now, my friend wants a 5.3 or 6.0. He wants to swap just the engine, keep the original tranny. Question, what kind of tranny do this trucks come with, it is a automatic tranny. How dificult will it be, I did a swapa 4.8 vortec in a 76 ford truck, so I have some experience with these engines. Any advise, any threads that I can follow up.
Thanks for your help
mlevario99 is offline   Reply With Quote
Old 07-16-2011, 10:44 PM   #2
Pop's C-10
Pop's C-10's Avatar
Re: 5.3 or 6.0 into a 82 GMC 4x4
There is a flywheel & spacer set up that allows you to use tha orig. trans. Is tha truck manual or auto..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-16-2011, 11:22 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
4l60e is what was stock on the ls motors, 6.0's had 4l65e or 4l80 primarily
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-17-2011, 11:11 AM   #4
mlevario99
the truck is automatic, and he wants to keep the original tranny, he just wants to swap the engine. If he uses the 5.3 he neds the spacer and flywheel, but if he uses the 6.0, do I still need the flywheel and spacer.
thanks
Old 07-17-2011, 12:07 PM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
You will need the spacer no matter what when using a LS with a older trans, unless you happen to find a 99-00 6.0 with the crank spacer built into the crank. Easy way to tell if you found one of those is it it has Iron heads.
I have this thread linked in the FAQ:
http://67-72chevytrucks.com/vboard/s...d.php?t=455803
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 07-18-2011, 12:25 PM   #6
mlevario99
so, besides the flywheel any other problems that I might encounter. From what I read on some of the threads, I need to locate the engine in the same location, so I need to find the engine mounts that will locate the new engine in the same location.
Old 08-21-2011, 10:34 AM   #7
Juiced06GTO
I just did the swap a year ago into my 87, the engine mounts I got did not move the motor back far enough. I had to weld a plate on to the stock motor mount pedastals and move the stock clam shells back. I then used the plates on my 5.3 to adapt them to the stock clamshell style mounts.
Juiced06GTO is offline   Reply With Quote
Old 08-21-2011, 03:28 PM   #8
Project77
i heard the 6.0's are way better than the 5.3 what year motor is it?
Project77 is offline   Reply With Quote
Old 08-21-2011, 04:16 PM   #9
Clyde65
Clyde65's Avatar
Juiced, did you use Dirty Dingo mounts? I have heard they allow you to move the motor an inch or two front to back if needed.
Clyde65
Rebuild of Clyde
support our troops!
