pitman arm help....
can someone tell me what is physically different between pitman arms for a 1972 2wd with power steering and without. I need to know if i have the correct one and i don't have the box anymore.
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
laying low
![]() Join Date: Mar 2001
Re: pitman arm help....
Just looking at the pics I cannot tell the difference. Could be the diameter of the pinion shaft or spline count I guess.
http://www.oreillyauto.com/site/c/se...ord=pitman+arm
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
The sector shaft is larger on a power gear box.
what's a sector shaft? I need to know if they are both the same overall length...
Watch out for your cornhole !
![]() Join Date: Jun 2003
The pitman arms are the same length yes, but like clinebarger pointed out, the splined hole that fits onto the sector shaft of the steering box is larger on the power steering pitman arm.
Basically, if your pitman arm will slide onto the splined shaft of your steering box, it's the right one.
