07-17-2011, 05:55 AM | #1 |
Building Dreams out of Dimes!
Anyone running 15x10" wheels (Preferabley Truck Rallies) with a 2.5" - 4" drop?
Hey guys I'm seriously thinking of getting the 15x10" truck rallies. I have 15x8" rallies now but I want to go with a big tire in the back without it looking too much like a donut.
My objective is to get the widest tire I can without rubbing. I still want it to appear stock with just a touch of the hot rod look. That's why I'm staying with the truck rallies. I would also like the tire to tuck under the rear fender well IF I can manage this without rubbing. (the tubbed look without the tub.) My truck has the 2.5" front - 4" rear drop. I was wondering if anyone was running the 15x10" truck rallies with the 2.5" - 4" drop. If so would you mind posting a few pictures as well as your tire size, and wheel size with the backspacing. Thanks guys!
1981 Chevy short/wide. SB400 350th |
07-17-2011, 08:49 AM | #2 |
Re: Anyone running 15x10" wheels (Preferabley Truck Rallies) with a 2.5" - 4" drop?
With a 15x10 wheel with 5" bs and 295/50/15 you will have about 1/4" clearance on the outside and a 1" clearance on the inside in the rear. 4'" drop won't tuck tire. I have a 7" rear drop with this setup and the top of the tire is even with the fender lip.
You may be looking for a taller tire though. Sorry don't have any pics yet. |
07-17-2011, 10:40 AM | #3 |
Redefining LowBudget
measure up what you have now then use a tire/rim calculator to fine out what will fit YOUR truck.....
the calculators are everywhere like tire rack just google it try this one http://www.1010tires.com/tiresizecalculator.asp
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
07-17-2011, 04:36 PM | #4 |
I am running 295 50 15s on my 8" rallies now and they are waaaaaay too short. I really would like to see pictures of the 15x10s tucking tires just so it will give me a real idea of how it will look. Thanjs for the tire calculator. It will get me close but I want to be certain before I spend the cash.
Anyone out there tucking rear tires running 15x10s? Posted via Mobile Device
07-17-2011, 04:43 PM | #5 |
Im running 15X6.5 215/70/15 front.
15X10 295/50/15 rear 5in back space. 2.5/3 drop. Sorry pics on next post #6
John 82 Chevy Silverado 350ci/TH350 |
07-17-2011, 04:45 PM | #6 |
07-18-2011, 12:02 AM | #7 |
Those tires look like the perfect width. I would just like that back tire a little bit taller maybe.
Do you have any side profile pictures? Thanks!
07-18-2011, 12:12 AM | #8 |
side
07-18-2011, 05:24 AM | #9 |
It seems that it doesn't matter if I'm running 8" wheels or 10" wheels. Either way the tallest and widest tire I can run is the 295/65-15.
http://www.summitracing.com/parts/MTT-3762R/ Tire Diameter 30.00 in. Section Width 11.90 in. Tread Width 10.90 in. Minimum Recommended Wheel Width 8.00 in. Wont tuck tires unless I do a flip kit... Oh well... Any suggestions? besides the obvious? thanks.
07-18-2011, 12:37 PM | #10 |
I have a pair of 15x10 Rallys with 5" backspace. What front wheels are most running with the 15x10's ? 15x6.5 or 15x7?
Frank
Born and proudly residing in a Red State ! Last edited by f.monroe; 07-18-2011 at 02:21 PM. |
07-18-2011, 01:30 PM | #11 |
I'm running 15"x 10" s with 5" bs on 315/60 mickys thompson radials,not sure what my drop is but it does tuck in there just a bit
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237 |
07-18-2011, 10:15 PM | #12 |
Yeah! I like that look! I also read a post that said u had stock fenderwells, stock reared, etc right? So if I get 15x10s 5" bs with 315/60-15s they should bolt right up with no problems. Right?
1981 Chevy short/wide. SB400 350th Last edited by Hazieview; 07-18-2011 at 10:28 PM. |
07-18-2011, 10:22 PM | #13 |
Nope its all stock under there , no trimming required !
07-18-2011, 10:47 PM | #14 |
I also found out that the 315/60s are only 1 inch wider from what I read. Now I have to decide if it is worth buying a set of 10" rallies. Hmmmm... decisions decisions.
07-19-2011, 09:33 AM | #15 |
1962 C-10
They're not rally's, but they are 10's...
15x7's up front with 235/60r15's 15x10's out back with 295/50r15's I'm not sure of the backspace...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
07-19-2011, 03:29 PM | #16 |
im sorry to thread jack, whats the widest tire i can fit on a 15x8 running a 60 or 65 profile? i know 275 will fit could i go up to a 295?
07-19-2011, 04:58 PM | #17 |
check out link below ramjams truck has 15x10 in the rear with some 275/60/15 tires
http://67-72chevytrucks.com/vboard/s...am#post4596376 |
02-13-2013, 10:15 AM | #18 |
Where can I buy the 15x10 rallies? I have 295/50/15's on my 8" rims and they just don't look good.
02-13-2013, 01:37 PM | #19 |
Summit Racing sells them. here ya go
http://www.summitracing.com/parts/wv...5042/overview/ |
02-14-2013, 02:07 PM | #20 |
Brothers also sells 8sand10s
05-05-2013, 12:02 PM | #21 |
73gmc454, that's a really nice truck!
too bad Chrysler Rallye's don't come 5x5 I really like those too... Unless someone knows where to get any
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
05-05-2013, 12:29 PM | #22 |
05-05-2013, 10:50 PM | #23 |
05-05-2013, 11:06 PM | #24 |
Hey Thacker, where did you get the side-pipes, and are they functional?
Nice truck buddy...
05-06-2013, 10:18 AM | #25 |
can you put a 325-50-15 tire on 15x10 gm rally wheel with a 5"bs with a 5/7 drop? Any pics?
