Old 07-17-2011, 02:40 PM   #1
jwbchevy502
1968 C10 Differential Capacity
Changing the oil in the differential. I believe I have a stock setup with 3:73 gears. Looking to know if anyone knows the capacity and should I use a synthetic or not?
jwbchevy502 is offline   Reply With Quote
Old 07-17-2011, 03:09 PM   #2
Wrenchbender Ret
Re: 1968 C10 Differential Capacity
It will take 4 pints. I dont use synthetic. I dont think its worth the extra money. A GL-5 rated gear lube is all you need.
Wrenchbender Ret is offline   Reply With Quote
Old 07-17-2011, 03:13 PM   #3
jwbchevy502
Thanks, I have the synthetic on hand so no issue. Thanks for the help
Old 07-17-2011, 03:51 PM   #4
cdowns
cdowns's Avatar
synthetic is far superior and well worth the money i run synthetic in engine tranny rearend and wheel bearings // it makes a true positive increase in gas milage and these trucks need as much help as possible when it comes to gettin better milage
Old 07-17-2011, 04:07 PM   #5
ubtripn
ubtripn's Avatar
I thought that if somebody switched to Synthetic after already using fossil based oil that it causes leaks by softtening the seals or something. Is that true?
ubtripn is offline   Reply With Quote
