Old 07-17-2011, 04:26 PM   #1
nrb's70gmc
nrb's70gmc's Avatar
22x14 wheels
i have my truck build ideas all sorted out in my head i just need a bit of help sorting out the wheels.
the wheels are 22x14 with 4.5 backspace
so can someone tell (about) how much the wheels will stick out past the fenders? so i get an idea.
its a 70 fleet side-axle will not be shortend
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
Old 07-17-2011, 04:36 PM   #2
jtp67-72
jtp67-72's Avatar
Re: 22x14 wheels
On a 14" wide wheel-it will measure 15" outer edge to outer edge--backspacing will be from back of hub to outer edge on back of wheel--so u wood have 11 1/2 " from back of hub-(face of drum ) to the outer lip of wheel-U can measure from your brake face out 11 1/2 " and that would be where wheel lip would be-remember you will also have at least 1" of tire pooch added to that!! jim
jtp67-72 is offline   Reply With Quote
