07-17-2011, 07:03 PM | #1 |
62 gmc suburban divorced Transfer case swap from a 221 to a 205: Need Help
My 221 divorced transfer case died on me, found a NP 205 divorced case from an 75 international PU. Want do I need to do the swap, mounts, u joints etc? No parts or mounts came with the 205.I need to fall back on everyones expertise.
Thanks, Tim |
07-17-2011, 07:59 PM | #2 |
Re: 62 gmc suburban divorced Transfer case swap from a 221 to a 205: Need Help
Gonna need a cross member for the t-case to bolt to, then mount it to the truck. Might get lucky on the joints, could all be the same size. If not, take one of each to NAPA and see if you can get a conversion joint.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
07-17-2011, 09:24 PM | #3 | |
Do you know if a Dodge or the International crossmember fit the best. Tim |
07-17-2011, 11:07 PM | #4 |
I've heard that the Dodge will go right in, just drill the holes and install some bolts. The frames have the inside width. Dunno bout the Intersmashable....
07-17-2011, 11:24 PM | #5 |
07-18-2011, 12:23 AM | #6 |
I've got a np 201 from an international with the crossmember and it fits. Not installed yet but measures up just fine. Same width frame too.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
07-18-2011, 07:51 PM | #7 | |
Does anyone have a crossmember and bracket for a International or Dodge 205/201 divorced transfer case. Thanks, Tim |
07-18-2011, 11:31 PM | #8 |
The one I have looks like it would be real easy to fab out of some 6"x2" c metal. I could take some measurements if you like. I'd post pics but the site won't let me for some reason
07-19-2011, 07:23 PM | #9 | |
Thanks, Tim |
07-20-2011, 08:30 AM | #10 |
Hopefully you got them. They loaded real slow. Let me know if you need more pics
07-20-2011, 08:07 PM | #11 |
