Old 07-17-2011, 07:28 PM   #1
pdxhall
pdxhall's Avatar
rear shock relocation
I am going to purchase one of the rear shock relocation kits that CPP and others carry but I have a question for anybody that has used them. Do the brackets replace the original brackets or work with the brackets? Right now I am tearing down and prepping the frame for paint and if I don't need the brackets I would just as soon remove them now.
pdxhall is offline   Reply With Quote
Old 07-17-2011, 07:30 PM   #2
SCOTI
SCOTI's Avatar
Re: rear shock relocation
They replace the original brackets.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-17-2011, 07:31 PM   #3
pdxhall
pdxhall's Avatar
Thanks! Now I can get back to the garage and fire up the grinder again.
Old 07-17-2011, 08:16 PM   #4
OneCoWBoY1992
why do so many ppl relocate the shock mounts? jw is it a bad place where they are sitting?
OneCoWBoY1992 is offline   Reply With Quote
Old 07-17-2011, 08:26 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
X2...they replace the original brackets.
They help with re-positioning the shock to a more vertical alignment (front to back) in lowered applications.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-17-2011, 10:17 PM   #6
SCOTI
SCOTI's Avatar
As well as regain some of the travel length by moving the mounts slightly farther apart.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-17-2011, 11:49 PM   #7
pdxhall
pdxhall's Avatar
Besides I get to grind off some more studs on the frame. (Like I need any more).
Old 07-19-2011, 02:12 PM   #8
65Gregg
65Gregg's Avatar
Read post 51 in the following thread, Lakeroadster outlines how to make your own.
http://talk.classicparts.com/showthread.php?t=13928
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 07-19-2011, 04:48 PM   #9
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Scotti wrote a DIY FAQ on how to make your old ones work like aftermarket...?
John
1999 Toyota Tacoma 4x4
Old 07-19-2011, 06:26 PM   #10
SCOTI
SCOTI's Avatar
I feel Lakeroadsters uppers offer better geometry if you can get the steel cheap enough. If not, tweaking the factory units gets the same results as the aftermarket stuff for a little sweat equity....
http://67-72chevytrucks.com/vboard/s...d.php?t=437582
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-19-2011, 06:36 PM   #11
oldblue1968chevy
yours looks better than lakeroadsters for sure though...both good ideas though!!
John
Old 07-19-2011, 06:59 PM   #12
Frizzle Fry
Frizzle Fry's Avatar
Hey pdxhall, I did mine 100% DIY front and rear. Here's the link. I can make more of the front relocators if you are interested. The rear only requires new shocks; no new brackets (front upper studs and modded lower OE brackets). I reused the lighter/well-broken-in former front shocks in the rear and put new Monroes in the front.
Frizzle Fry is offline   Reply With Quote
Old 07-20-2011, 01:37 AM   #13
pdxhall
pdxhall's Avatar
Frizzle, I like the look and location of the rear shocks. I think I might give it a try, it looks real simple. I just tore down the rear end from the trailing arms and shock mounts tonight so I think I'll mock some up. What bolt did you use for the top mount? It looks like a front upper mount from the pix, is that so? I've got the front suspension done (2.5" spindles and 1" drop springs so I don't need the front relocated. I've got 5" drop rear springs and new shorter shocks for the drop in the rear.
Old 07-20-2011, 09:39 AM   #14
66farmer
66farmer's Avatar
PDX
Some how I ended up with one extra EC rear shock relocater you can have if you like.
66farmer is offline   Reply With Quote
Old 07-20-2011, 11:43 AM   #15
Frizzle Fry
Yes, I used the OE front upper mounts in the rear. Also used my old front (soft) front shocks in the rear. You can really feel the improved ride and handling. Very stable on the freeway. Further improvement plans are for jeep rear springs and a 1.25" front sway bar. Come drive it if you want.
Old 07-20-2011, 04:17 PM   #16
pdxhall
pdxhall's Avatar
Thanks for the offer Farmer but I think I'm going to try Frizzle's approach. Thanks for the drive offer Frizzle but I don't know when I'll be able to make it over that way, lots of things going on right now. I finished school and I'm in job search mode right now. I'd like to make it over to the cruise in again but not sure when. By the way, is that paint job on your truck an "ole skool" special?
Old 08-08-2011, 04:35 PM   #17
Frizzle Fry
Did you get this done?
Old 08-09-2011, 01:25 AM   #18
pdxhall
pdxhall's Avatar
Frizzle. No, not yet. I've been cleaning up the frame, got the trailing arms blasted, and removed a couple of crossmembers to fit my rear fuel tank but that's it. Been real busy with some other things. I did make it over to Beaches a couple of weeks ago. I saw your truck but you were nowhere to be found. I crawled under your truck and took a look at your shock setup, though and I'm convinced I'm going to try it. I just wonder if the top mount could be beefed up a little more. What are your thoughts on that?
Old 08-12-2011, 10:19 PM   #19
Frizzle Fry
Ugh, too bad we didn't meet up!
That was my initial instinct on the upper mounts too, but I figured if it's good enough for the front (much heavier) it's gotta be good enough for the rear. My 69 Tahoe with BBC has the same upper mounts up front.
