07-17-2011, 11:59 PM | #1 |
Factory hood hinge mod help
I remember reading a mod that someone did with their factory hood hinges. What I remember is they removed the big bulky spring and had used a gas shock similar to what is used on a hatchback. I think the thread had some real good pics. The help I need is finding the thread. I have a good idea on how to do it however the idea stemmed from this post that I have searched and searched for.
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
07-18-2011, 01:00 AM | #2 |
~Rest In Peace~
Re: Factory hood hinge mod help
i know there some billets hood hinges with gas shocks but there about 600 bucks
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
07-18-2011, 02:02 AM | #3 |
Ya i have seen the ones you are talking about this would use the factory hinge without the spring and use a gas strut about 18" long
07-18-2011, 09:29 AM | #4 |
this would be a great mod. i would also like to read up on this
1968 chevy c10 lwb, 250 inline6, 4 speed, |
07-18-2011, 10:06 AM | #5 |
Has more rust than truck...
All the way at the bottom.
http://67-72chevytrucks.com/vboard/s...=221437&page=8 Then there is also the porterbuilt option... http://www.porterbuiltfabrication.co...tarting-at-265 |
07-18-2011, 11:36 AM | #6 |
low n' slo
would those clear on a bagged truck?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
07-18-2011, 06:25 PM | #7 |
Usmcchevy that's it! That looks like the same build I seen it in! Thanks
07-18-2011, 06:28 PM | #8 |
Not sure keV my truck is bagged, aired out the fenders sit on the tires in the front so on my truck as long as it's above that height I should be fine.
07-18-2011, 06:36 PM | #9 |
low n' slo
from the pics it seems like it would close!
i had to pull my fenders and just for good measure pulled the heater box. i might even have to trim one of the mounting holes off the hinges... wonder if a shock could be put in place of the spring instead of mounting a long one like the one in the pic..?
07-18-2011, 07:27 PM | #10 |
I have seen some aftermarket ones similar to what you are talking about but the strength of the gas shock would be crazy to only be 6" long
My thought was to use the shocks and then a door pull kit on the hood latch with a keyless remote would be a cool little mod to open the hood Posted via Mobile Device
07-18-2011, 07:38 PM | #11 |
low n' slo
good point, probably why they went with a huge strut lol
hood latch idea sounds cool though, would like to see that setup
