Old 07-18-2011, 11:29 AM   #1
68 IRON
68 IRON's Avatar
Shift indicator repair?
I have a replacement indicator to install and want to unplug the fiber optic at the indicator...can it be done? I dont want to brake anything. This will replace a loose, barely hanging on indicator. I want to leave the working fiber optic and just replace the indicator...any tricks or cautions?
The indicator I pulled from the "donor" the cable was pinched off at sometime.
Do I just grab the cable with needle nose and pull?
68 IRON is offline   Reply With Quote
Old 07-18-2011, 02:31 PM   #2
red71c10
The Red Menace
red71c10's Avatar
Re: Shift indicator repair?
It's been a while since I replaced mine, but it was very easy. Kind of hard to describe, but if you slide the orange indicator out of the housing, you will see that the optic pops out with just a little manipulation.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 07-18-2011, 03:02 PM   #3
68 IRON
68 IRON's Avatar
So the red/orange portion will seperate from the black portion...is this correct? Then I should be able to remove and replace the optic cable end.
I'll give it a try when I get home tonight....Thanx!
Old 07-18-2011, 09:50 PM   #4
68 IRON
68 IRON's Avatar
Red, you were spot on. Thanks again.
Old 07-18-2011, 11:49 PM   #5
red71c10
The Red Menace
red71c10's Avatar
Glad I could help!
