Old 07-18-2011, 12:04 PM   #1
ges55
BLACK SATIN
ges55's Avatar
temp gauge after installing V8
We just put in a 1985 305 V8 in my 67 3/4 ton that had a 250 in it. The temp gauge goes from below the lowest mark to just over the lowest mark at operating temperature. I bought a huge aluminum radiator for it & a friend checked the temp with his no touch temp meter & got only around 164 degrees. How can I get the temp to go in the operating range on the gauge? I don't know what t-stat is in the newer motor.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
Old 07-18-2011, 12:52 PM   #2
bosco200
bosco200's Avatar
Re: temp gauge after installing V8
what degree of thermostat is in it now?
bosco200 is offline   Reply With Quote
Old 07-18-2011, 03:14 PM   #3
ges55
BLACK SATIN
ges55's Avatar
I don't know which t-stat is in it now.
Old 07-18-2011, 04:09 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
If it were me I would put a 180 degree thermostat in it and then see what the temperature gage reads.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-16-2011, 09:11 AM   #5
ges55
BLACK SATIN
ges55's Avatar
It had a 195 degree t-stat in it. I put in a 180 degree t-stat & it hasn't changed. Somewhere I heard something about the ground on the motor?
Old 09-16-2011, 10:36 AM   #6
bean
i had the same problem. replaced the temperature sending unit with a better one i purchased thru Eckler's. Problem solved
bean is offline   Reply With Quote
Old 09-16-2011, 10:38 AM   #7
lyrikz
PITbut
lyrikz's Avatar
I ran into something similar. What you need to do to save you some time is first go get a new guage and install it. Get the engine up to operating temperature and make sure its actually running at the correct temp. If it is you have some options. What i did was just replaced my factory guage with the aftermarket autometer. I just removed the face and used the factory guage face. Works perfect.
My guage was reading normal at freeway speeds then would peg hot at idle. My guage spring in my old ass guage just wasnt working correctly...
As for grounds. You should have a few on the truck.. Frame to engine, frame to cab. Good grounds are a must.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 09-16-2011, 10:48 AM   #8
PHAT TONY
PHAT TONY's Avatar
I've tried many new temp senders and have yet to find one that works correctly with factory gauges, in more than a few trucks. My Blazer reads as yours does now.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 09-16-2011, 10:56 AM   #9
ges55
BLACK SATIN
ges55's Avatar
The temp gauge worked fine with the 6 cyl motor in it. I did replace the sender & no change.
Old 09-16-2011, 11:05 AM   #10
bean
i was told the temperature send units you get thru the local parts places are junk. the one i got thru ecklers was like 25 buck i think. but once installed it works great.
Old 09-16-2011, 11:49 AM   #11
Jofin66GTO
I'm having the same problem now. I see one post for gauge and another for sending unit. All that's left is the wiring haha. Please post what you did to fix. Thanks
She's gonna go, or she's gonna blow
Jofin66GTO is offline   Reply With Quote
Old 09-16-2011, 12:05 PM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Try the sending unit out of the 6.It should go back to reading like it alweays did.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-16-2011, 12:48 PM   #13
Jofin66GTO
Ok. Figured out a good indicator. The temp gauge works off resistance value of sender unit. To see if it's gauge or sender. Just ground the sender unit or wire to it and turn on key. If gauge pegs to hot then your sender is bad.
Now granted I'm still troubleshooting mine, so I'm not leaving out possibility that low coolant or air or another such factor is in effect. My gauge pegged so now to figure out range of sender unit both cold and hot
I'll then read it cold and throughout warm up till run and read ohms on sender unit. I think it goes from 220 ohms cold to 68 ohms at middle of gauge. Hope this helps
Old 09-16-2011, 01:09 PM   #14
ges55
BLACK SATIN
ges55's Avatar
I was going to try the old sender, but it has different size threads.
Old 09-16-2011, 01:10 PM   #15
lyrikz
PITbut
lyrikz's Avatar
No, thats not right. To test to see if the guage is working, you ground it.. It SHOULD peg.. If it pegs its reading right. The correct way is to find the resistance of the sending unit, and the resistance of your guage in your truck.. The issue is, that guage is old man. So the resistance changes over time.
Mine did. Change the guage out and be done... Quick/ easy/ more accurate.
and sold.
Old 09-16-2011, 01:19 PM   #16
lyrikz
PITbut
lyrikz's Avatar
This is funny cause i went through this EXACT thing. Used different senders, aftermarket and expensive. Nothing worked. My guage had just become to week.. So when it was at the correct ohms for 190 degrees it would go all the way to hot.
and sold.
