Old 07-18-2011, 12:31 PM   #1
BigTallWayne
'94 Cheyenne no longer strong
Hello, my vehicular pride and joy is a well loved 1994 Cheyenne pick up 6 cylinder 2wd. My family bought it new, 2+kids have learned to drive on it, and it's never let me down... Untill now.
It's a stick shift, with no tachometer, so I figured in my infinite wisdom about 3 months ago that I needed to put a tach on it. I purchased one at a local auto parts store, followed the directions, and it worked great, except now Truckasarus no longer runs as normal.
I promptly removed the tach, put everything back the way it was, and it still does not run right. Whether or not the issue is related to this attempted install I do not know.
From a cold start, it sputters, and struggles while idling, after it warms up a bit, it sounds a bit sweeter, but still has some stutters. When you try to step on it, it's not as quick to respond, and it's noticeable that there have been some horses that have escaped from the system.
It does still run and drive, recently (within past 500 miles) I have replaced, plugs, wires, air filter, distributor cap and rotor. Friends have suggested to replace fuel filter as well.
Since my family has owned the truck, it's seen the above repairs, regular lube oil filter, and 2 clutches.
Any suggestions on where to start would be awesome.
Thanks,
Big Tall Wayne
BigTallWayne is offline   Reply With Quote
Old 07-18-2011, 03:52 PM   #2
Tom
driving is in my blood
Tom's Avatar
Re: '94 Cheyenne no longer strong
Start with fuel pressure, what is it?
