Old 04-04-2003, 11:30 PM   #1
trailwart
trailwart's Avatar
cab ????
at what point would you guys consider a cab total loss and start looking for a replacement. im in a situation of having to put new cab corners,floor pans,rockers, and thats just lookin at it with out having it removed from the chassis. i might find even more i need to replace once i get into it a little more. so i guess my Q is should i dump the money in this cab or find a good one.
72 chevy 3\4 ton 4 speed 4x4
84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories)
1999 suburban 4x4
1982 chevrolet S-10 V-8 (Thanks uncle EARL)
trailwart is offline   Reply With Quote
Old 04-04-2003, 11:41 PM   #2
Class of 69
Class of 69's Avatar
How far from Michigan are you willing to travel for a good cab?? My guess is all the cabs in your area are about the same as yours, so you need to figure cost of repair to yours, and cost to buy and retrieve a good cab somewhere else. Body panels aren't all that expensive....it's the labor to install if you can't do it yourself. You may only have $250.00 in sheet metal to repair yours.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 04-04-2003, 11:50 PM   #3
Dean23
68cst_ss490
Dean23's Avatar
my cab up here needed rockers corners floor pans mounts and kick panels...... save it if you can the replacement parts are cheap, and then you atleast know what you have when its all done. jmho
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 04-04-2003, 11:54 PM   #4
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
i'm putting in inner and outer cab corners, driver side and passenger side floor pan, inner and outer rocker panels and a few other various patches. i figure i have the cab, why not try to fix it?
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 04-05-2003, 12:28 AM   #5
minibike
minibike's Avatar
As long as the firewall, cab supports and window channels are in good shape, I would try to fix it.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 04-05-2003, 09:59 AM   #6
Seke69
Space Cadet
Seke69's Avatar
even if you find another cab in your area you'll probably have to do some repairs to it too... patches are pretty cheap and if you've got the tools you should do it yourself. I know I will be, mostly because I'm not doing the total resto thing and see no point in ruining a great cab that might be more appropriate for true restoration.
Seke69 is offline   Reply With Quote
Old 04-05-2003, 10:04 AM   #7
Class of 69
I meant to bring up the fact that anything else you find would most likely need some repair too. A true rust free cab is gong to cost a LOT, and be far from home! Seke69... where in the Twin Cities are you?? Is that TC MN?
Old 04-05-2003, 10:20 AM   #8
dmurphy68
Dont forget for about $450 bucks you can get a glass cab
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour.
- George Washington
No free man shall be debarred the use of arms
- Thomas Jefferson
Later Darren
http://www.myspace.com/dmurphy68
dmurphy68 is offline   Reply With Quote
Old 04-05-2003, 12:19 PM   #9
jay-dawg
chevelito
jay-dawg's Avatar
yours sounds real nice compared to mine:
1)large gaping hole where roof meets driver door.
2)front of inner roof is gone
3)dash on passenger side is completely rusted and apart from the pillar
4)extra large hole next to master cylinder (looks factory but it really is a rust hole)
5)both rockers are shot
6)both cab corners are shot
7)hole on firewall above heater box
so.....in other words, mine is a "total loss"
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 04-05-2003, 12:37 PM   #10
stateamind
And you call that a what?
stateamind's Avatar
glass cab? where can one find info on such a thing?
stateamind is offline   Reply With Quote
Old 04-05-2003, 01:57 PM   #11
1969 GMC
1969 GMC's Avatar
weird rust
My truck was Ziebarted when it was new or relatively new, and maybe it helped in a few aspects. I guess my original rockers were shot, because the replacements that I have now are shot too. Cab corners are shot. Floorpan is immaculate...I have no idea why. Its original too. Both front floor supports are shot, and there is maybe a tiny spot of rust thru on the lower corner of one of the bed wheelwells. Door bottoms a little rusty. There is a small spot on the engine side of the firewall where the chalkmarks are. And then there are my kick panels. They are toast. Not just the bottom by where it meets the floor, I mean where the vent is they are rusted out. I guess I need patches bad. I don't wanna scrap my cab, its in good shape otherwise, plus I'd have to find another clearance lamp cab, which would be harder to do. This sounds bad, but is good for Ohio (and thats because the truck is from Minnesota!).
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-05-2003, 02:02 PM   #12
adamls
Gotta Startem Early
adamls's Avatar
FiberGlass Body Parts
Try www.usbody.com for almost all glass parts on these trucks.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
