Old 07-18-2011, 01:21 PM   #1
mcfarlnd
61 suspension swap questions
I found a 85 chevy truck complete front end with everything i need for the swap for 100 dollars. If I swap to the 77-87 front suspension on my 61 will I be able to retain the 235 straight 6? I have a 5.3 I am building but it's not ready to be put in at this time and i don't have alot of time to do this because I am movin to California in September. Trying to make as much progresss as I can and keep the truck diveable.
mcfarlnd is offline   Reply With Quote
Old 07-18-2011, 03:24 PM   #2
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: 61 suspension swap questions
I'm sure you can keep it but if you're short on time you can always do it after the move.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 07-18-2011, 05:24 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I think frame width may be an issue. Other will chime in on that.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-18-2011, 07:06 PM   #4
mcfarlnd
Frame width will be an issue??? What exactly do you mean? I'm going off a sticky on this site (http://67-72chevytrucks.com/vboard/s...d.php?t=366850) Are you talking about the K member fitment?
Old 07-19-2011, 01:26 AM   #5
Captainfab
60-66 Nut
You could keep the 235 after the suspension swap. You would just have to have a front motor mount like the original. You could likely utilize the motor mount bracket off of the original crossmember, and either weld it to the '85 crossmember, or modify it to bolt on.
Old 07-19-2011, 02:07 AM   #6
iehotrod
iehotrod's Avatar
Wait I seem to agree with 61 FL Apache I do believe the width of the frame rails are two different sizes. One example I can give you is I tried using the rear bumber from my 63 on to the 62 and it was way off. I do not have the 63 here other wise I would measure them both. I know the 63-87 is the same size in the front k-member and Ithink 60-62 is the same and you may not be able to use anything from 63-87 k-member if I wrong please correct anyone. I wish both trucks were here today so I can can firm it.
iehotrod is offline   Reply With Quote
Old 07-19-2011, 08:59 AM   #7
mcfarlnd
Well I guess this is why they make torches and welders. If it is too wide I'll just section it. If it is to narrow I will section it and add material as needed. I think I am gonna stick with nacho dog and just do the swap after I move.
Old 07-19-2011, 02:27 PM   #8
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
the rear frame is definitely wider on 60-62, however going by markeb01's description , the front is just a bolt and drill affair.
