Old 07-18-2011, 02:46 PM   #1
NC67Chev
NC67Chev's Avatar
Going back to stock height question
So, I've been pondering it for a long time and I think I've come to the conclusion that I would like to go back to stock height. Anyway, when I went with the 2/4 drop, I installed shock relocators. Do I need to re-install the factory shock mounts? Or, will I be okay to leave the relocators on?
Thanks!
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 07-18-2011, 03:52 PM   #2
SCOTI
SCOTI's Avatar
Re: Going back to stock height question
Thanks!
Raise the truck back up & measure the distance between the shock mounts. Compare that dimension w/the shocks length (max compression, max extension, middle of travel) & you'll know.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-18-2011, 05:52 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
John
1999 Toyota Tacoma 4x4
Old 07-18-2011, 06:37 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
ok i went with a two inch drop then i just switch to stock height spindle and i dont know if the truck was relocated shocks or not but i order stock height shocks and they fit with no problem i do have a 1 inch drop spring as well
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-18-2011, 06:42 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
oldblue1968chevy this is not a "For Sale" post, please don't turn it in to one.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-18-2011, 07:01 PM   #6
nds1968
nds1968's Avatar
Would the shock angle be different or if it was it wouldn't matter?
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 07-18-2011, 07:59 PM   #7
SCOTI
SCOTI's Avatar
As the truck is lowered, the shock angle changes. The relocators restore some of that 'change' & allow for more travel. Raising it back up w/the upper mount still in place would likely allow for a slightly different angle vs stock.
Does it matter? It would prob be a wash or slight improvement as it would likely position the shock a little closer to vertical.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
