US Army Veteran
![]() Join Date: Nov 2008
1959 Impala Steering Wheel - What do I need?
Hey guys,
I'm considering installing a repro 15" 1959 Impala steering wheel. I have a 78 original steering column with tilt. The wheels are designed for the 59 steering column. Have been scouring the web and this site for the past day trying to determine what I need. Wondering if anyone has done this, with the horn working, and what I need to pull it off? http://www.classicchevy.com/chevy-st...1959-1960.html Horn kit: http://www.classicchevy.com/chevy-ho...Product_Viewed And then an adapter to late model steering columns: http://www.classicchevy.com/chevy-st...Product_Viewed Is that pretty much all that's needed? Any surprises I might encounter? Hate to invest that kind of money to find out something won't work!
1972 C10 Highlander - The making of a daily driver |
Re: 1959 Impala Steering Wheel - What do I need?
In addition to what you have already listed I would think you are going to need some kind of adapter to install that steering wheel on the later model tilt column you have, have you contacted Ecklers to discuss your project with them? they should be able to provide the necessary parts you will need to install on that late model column.............then be sure to post pics for us once you have completed the install.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
Old Heap Driver
I have a 62 Impala wheel on a 87 Blazer tilt column. The horn wouldn't work consistently so I went with a floor mounted momentary switch next to the dimmer. The splines on the wheel lined up with the steering shaft without any issues.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
Got any pics of your wheel...s10 fan
Posted via Mobile Device |
Old Heap Driver
This is the only one I have, ignore the dash panel please, the dash was undergoing a makeover.
The One And Only !!!
That's alot a bones for a steering wheel.....
![]() Looks sharp Bryan !
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
That looks nice.... I was looking at a56 impala but I like that one to ... Ever get the horn working... .
#8 | |
![]() Join Date: May 2009
56 Impala`s don`t exist. The Impala did not come out until 1958.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
Old Heap Driver
I didn't mess with the horn any further. The floor switch works well for me.
Sorry bout that "58"..... I'm mixing to old and the new..... my truck is a 87 r10 and so far the interior ranges in years from 1972 to 2004 merged together...
Tags |
impala steering wheel |
