Old 04-05-2003, 12:16 AM   #1
ScottH
ScottH's Avatar
Will a 275x60 tire fit a 10" rim?
Can anyone tell me if I can install a 275 x 60 tire on a 10" wide rim? Any info is appreciated.
Thanks!
ScottH is offline   Reply With Quote
Old 04-05-2003, 01:28 AM   #2
GreenMystChevy
I have 275 x 60 R15's on my Chevelle. They fit great and look great! I doubt you can see from my picture that I have on my website.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 04-05-2003, 01:31 AM   #3
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Yes.....I have a 71 with 275/60's on a 15x10" rim with 4 1/2" backspacing all the way around. I can post a pic if you want.
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 04-05-2003, 01:48 AM   #4
Chevy Wrench
former desert rat
Chevy Wrench's Avatar
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
Yes, but Im running 275/40 18s on 10 inch wheels on the back of my 94. They look great. Same width, just lower profile sidewall.
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const.
Chevy Wrench is offline   Reply With Quote
Old 04-05-2003, 01:58 AM   #5
mikep
Used to have a truck
mikep's Avatar
here they are on 8 inch rims on my last car.
No truck :-(
mikep is offline   Reply With Quote
Old 04-05-2003, 03:33 AM   #6
gmc67swb
gmc67swb's Avatar
YEAH THEY'LL FIT. I HAD 275/60-15'S ON 10" RIMS. THEY KINDA GET A LITTLE LOOK LIKE THE RIM IS WIDER THAN THE TREAD THOUGH.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 04-05-2003, 11:21 AM   #7
mikep
mikep's Avatar
That tire is really better suited to 8 inch rims. 295/60-15's would be better for a 10 inch .
No truck :-(
Old 04-05-2003, 12:37 PM   #8
lngbed71
lngbed71's Avatar
Here are my wheels and tires on the truck.
Land of the free
Old 04-05-2003, 02:10 PM   #9
71Rat
ran out of money
71Rat's Avatar
lngbed71- how much did you lower your truck?
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 04-05-2003, 05:40 PM   #10
Dreaminator
Dreaminator
I am running Toyo 60/285s in the back on 17x9 Cragar ss's. Had to adust the stops on the front with 60/255s on the same rims. My drop is 3.5 front and about 5 in rear. The 255s ride the 17x9 well too. Check with the tire people as MikeP may be right. Finally, DO NOT buy any rims until you are sure they fit the way you want. Remember to check rear inside clearance. have some fun.
The Dreaminator
Daily Driver 1971 Cheyenne 10 Lwb Tilt/Tac 402 .030 TH400.
Dreaminator is offline   Reply With Quote
Old 04-05-2003, 07:23 PM   #11
lngbed71
lngbed71's Avatar
71 Rat.sorry so long for a post back. 3" spindle drop in the front, 4" coil in the back.
Land of the free
Old 04-05-2003, 09:19 PM   #12
ScottH
ScottH's Avatar
Thanks to everyone for the great info as usual!!!
Old 04-05-2003, 10:20 PM   #13
shortbed70
shortbed70's Avatar
I've got 295-50 15x10 and I like the look with 10" hittin the pavement
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-06-2003, 10:04 PM   #14
71Rat
ran out of money
71Rat's Avatar
thank you lngbed71- that is really a nice truck you have. i am going to be dropping mine 2 1/2 in the front and 4 in the rear... so hopefully i will be around the same hight as yours, thanks again
Old 04-06-2003, 10:38 PM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have 275/60 on mine mounted on 9.5 inch rims, they fit perfect.
Old 04-06-2003, 11:18 PM   #16
crazy longhorn
Fabricate till you "puke"
You can run the 275/60s on anywhere from an 8 to 10" wheel. Mine are on 8" wheels. Looking at the tread width(8.8, if memory is with me), it would indicate that an 8.5 to 9" wheel would be optimum for the tire......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
