07-18-2011, 10:05 PM | #1 |
Did 72 chevy 1/2 Ton short box come with coils up front and
Leafs out back???? I want to do the 4/6 ECE kit. Do I need to do something different....
Thanks Brett Posted via Mobile Device |
07-18-2011, 10:33 PM | #2 |
67-72 parts collector,…
Re: Did 72 chevy 1/2 Ton short box come with coils up front and
Yep,... some had leaf springs.
ECE sells a drop leaf spring pack with a longer rear shackle. DJM sells a flip kit. That's the only two choices. I'm not sure which shocks you need for these options, though. Call ECE and they will fix you up.
07-18-2011, 11:01 PM | #3 |
So would u go with ECE or DJM?? Will longer shackles effect the ride in a bad way??
07-18-2011, 11:35 PM | #4 |
I would go with ECE.
They have great products and customer service.
07-18-2011, 11:36 PM | #5 |
You might search the board for lowered leaf spring trucks.
I can't give you any personal experience with lowering a 67-72 truck with rear leafs.
