Andy
I am replacing the manual steering box on my truck with a power steering setup and I cannot get the pitman arm to go into the center link. To me, it appears that the pitman arm is about 1/2" too long. Were there different length pitman arms for power steering? My truck is 2wd. I've tried to get it in there with the wheels straight, at full lock both left and right and it just won't go. Any advice?
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi 1969 CST/10 383|Aisin AR5 5 speed 1972 K5 350|Turbo 350 4x4 2005 Duramax 2500HD 4x4 |
Re: pitman arm issue
The manual and power steering pitman arms are different (not sure of the difference though). If you changed the steering box I think you would need to change the pitman arm as well. That's probably your problem.
1970 Chevy LWB - 305/350 In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's. |
Andy
I have the power steering pitman arm on the truck now. I ordered a new one when I ordered the box. I'll take a picture tonight.
