07-19-2011, 05:21 AM | #1 |
HOW ON EARTH, is this fixable!!
Hey everyone Im in process of a resto on my '68 C-10 and ran into a few snags. Some rust in unwanted places. Here in MN it is all to common. Any help on how to repair this or are these parts available aftermarket would be such a HUGE help to a newbie such as myself. The bottom pic is of my rear coil spring mount at the frame and the top pic is, im sure all you guys know, is the front upper a-arm tower. Im running out of ideas on how to fix/repiar these. Im an excellent welder, so metal fab wont be a problem if need be. Any pics of your repairs if you've run into this would be a tremendous help.Im pretty new to this site and I really appreciate all the help I have been getting so far!!
07-19-2011, 06:16 AM | #2 |
Re: HOW ON EARTH, is this fixable!!
It might be easier to buy some good used parts from one of the boardmembers, grind off rivets, and bolt on new used with grade 8 hardware.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
07-19-2011, 06:25 AM | #3 |
Thats a good idea. That don't look safe.
07-19-2011, 06:33 AM | #4 |
Collector of Projects
Front suspension
CHEAP fix: Convert to 1973+ front suspension.... Cool but more $$: Porterbuilt front suspension Rear suspension Cut it out, build a new crossmember, add air bag plates.... |
07-19-2011, 09:14 AM | #5 |
It's all in the timing
X2,That looks scaaaaary!As rsavage said keep checking the parts board or you could do as mcmlxix said and convert to a 73+ front end and have disk brakes.
The Dude Abides. ---------------------- I aint sayin, I'm just sayin. |
