Old 07-19-2011, 08:33 AM   #1
ubtripn
ubtripn's Avatar
Synthetic or Regular Differential Oil
Is it ok to put Synthetic in my differential after it has been running fossel based, regular oil for so may years? I heard it will looseen seals, cause leaks, etc.. if you switch midway through with any engine.
ubtripn is offline   Reply With Quote
Old 07-19-2011, 09:25 AM   #2
70cst
70cst's Avatar
Re: Synthetic or Regular Differential Oil
Some reading for you ...
fluids/oils/gear lube
http://67-72chevytrucks.com/vboard/s...d.php?t=177957
someone please tell me this guy is full of BS
http://67-72chevytrucks.com/vboard/s...d.php?t=378304
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-19-2011, 09:26 AM   #3
ubtripn
ubtripn's Avatar
Old 07-19-2011, 09:30 AM   #4
70cst
70cst's Avatar
Originally Posted by ubtripn View Post
Glad to help. I try and do one good deed a month
Old 07-19-2011, 09:42 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
synthetc oil is the best thing you can do for your diff.
Old 07-19-2011, 09:56 AM   #6
cdowns
cdowns's Avatar
i use synthetic lubrication in everything motor tranny rearend and also wheel bearings// have had noticable increase in milage and slightly more performance in my real world test uses
the last two new GM vehicles i got came with synthetic right from the GMfactory//2004silverado and 2008 HHRss
Old 07-19-2011, 10:13 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My K20 had dino in the diffs (& t-case) for close to three decades before I changed to synthetic. No problems....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-21-2011, 03:12 PM   #8
ubtripn
ubtripn's Avatar
Right on, synthetic it is. Thanks!
Old 07-21-2011, 03:31 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Unless it has a positraction rearend. Some Synth oils aren't compatible with a positraction diff. Or the other way around...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-21-2011, 03:35 PM   #10
cdowns
cdowns's Avatar
Gary
most all synthetic i know of is no problem in posi rears in fact most you dont even need a posi additive like you do with dinogrease
Old 07-21-2011, 08:16 PM   #11
Longhorn Man
yeah... I've never heard of that one. Sounds like yet another one of the millions of myths about synthetic oils.
Old 07-21-2011, 09:27 PM   #12
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
great my parts guy told me synthetic is a fluke and i put dino in my diff lol
John
1999 Toyota Tacoma 4x4
Old 07-21-2011, 10:50 PM   #13
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
I am running Redline Heavy Shockproof in my rear, its a posi and did not do the additve as directed by the shop that built the rear. The owner told me he tested diffrent brands at the track and the Redline proved to run cooler thus working better to reduce friction
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
