Old 07-19-2011, 09:27 AM   #1
remist17
remist17's Avatar
Seat belt question
I need to replace the seat belts in my 87 regular cab with the stock bench. Can anyone tell me if 93-99 seatbelts will bolt in ?
Is there a good aftermarket vender that sells belts cheap?
2013 Chevy Silverado, Z71, 5.3L, 4 door
2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40
Support the Troops.
remist17 is offline   Reply With Quote
Old 07-19-2011, 09:51 AM   #2
tucsonjwt
Re: Seat belt question
I don't know about the 93-99 belts working in your truck, but you can check this website for replacement belts. I know guys who restored their old vehicles and liked their belts - but they can be pricey.
http://ssnake-oyl.com/
LMC and Classic Parts have the belts also. If you can get the GM part numbers for your belts I think it would be worth a look on oehq.com, oewarehouse.com, autopartstomorrow.com, and GMpartsdirect.com. Or, just do a google search for the part numbers.
tucsonjwt is offline   Reply With Quote
Old 07-19-2011, 12:19 PM   #3
remist17
remist17's Avatar
I looked at some of the parts wearhouse sites (Discount Car Parts Stuff). They offer lap but it says passenger side and driver side. The description is as follows :
Universal 2-point seat belt, 1.75" width x 54 inch full extend length. 10mm bolt mounting, comes with center push buckles.
Is this right for the center lap belt?
Support the Troops.
Old 07-19-2011, 01:00 PM   #4
tucsonjwt
Check LMC, page 112, $90 per belt, 3 point, OEM like.
Check Classic parts, page 34, $90, 3 point retractable.
My catalogs might not be the newest, so page numbers might be wrong.
Old 07-19-2011, 03:24 PM   #5
remist17
remist17's Avatar
My main issue is the lap belt. Will the one on LMC work (standard two point lap) for the middle bench seat.
Support the Troops.
Old 07-19-2011, 06:01 PM   #6
juiceman650
juiceman650's Avatar
The two point lap should work if its the one from LMC. I replaced all 3 seat belts in my 75 with seat belts from LMC.
juiceman650 is offline   Reply With Quote
Old 07-19-2011, 06:39 PM   #7
Jonboy
Slots go on anything!
Has anyone else used the 3 point aftermarket belts? The later ones don't really fit the floorpan in my '74, but i would also like to be able to put a child seat in there, too.
1974 Jimmy- 5.3/4L80e/NP241
Old 07-19-2011, 07:48 PM   #8
DarkReaper79
I got mine here http://www.gotbelts.com/ for my 73
DarkReaper79 is offline   Reply With Quote
Old 07-19-2011, 08:01 PM   #9
broey
Square
broey's Avatar
I bought the 3 point belts from lmc, they are decent, but didn't mount as well as I would have liked.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 07-20-2011, 03:05 AM   #10
juiceman650
I had the same problem in the driver and passenger sides.
Old 07-21-2011, 11:32 AM   #11
remist17
remist17's Avatar
how does the center lap belt remove and install?
Support the Troops.
Old 07-21-2011, 02:17 PM   #12
Moostifer
a fool with no money
Moostifer's Avatar
i bought the 3 point belts from lmc, they are decent, but didn't mount as well as i would have liked.
x 2
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 07-22-2011, 11:57 AM   #13
remist17
remist17's Avatar
does any one have photos or can tell me how to upbolt the center belt. Honestly I have not looked at it. Do I need to remove the seat?
Support the Troops.
Old 07-22-2011, 12:02 PM   #14
juiceman650
You have a bench seat right? Try sliding it toward all the way and check to see if you can see the 2 bolts near the middle of the cab.
Old 07-22-2011, 12:14 PM   #15
I used ones from a 94 extended cab in my old 82. Everything bolted into the stock locations.
Old 07-22-2011, 03:44 PM   #16
remist17
remist17's Avatar
Thats interesting.... a 94 bolts in. I might be going to the junk yard!
Can anyone tell me how the retracter bolts in? Do I need to take off the plastic cover to get to the bottom bolts? I understand how to take off the top one on the top pilar.
yes I have a bench seat. Tehe truck is at paint right now so Iwill check it when it gets back
sorry for all the dumb questions just never tried this before and not sure what I need.
Support the Troops.
Old 07-22-2011, 04:54 PM   #17
juiceman650
Yeah, you have to remove the plastic. It's pretty simple, just get yourself a wrench, or a ratchet with some sockets. I forgot the exact size of the bolt, but on the floor of the cab your dealing with about 4 bolts holding all of the seat belt equipment. Oh, and there's no such thing as "dumb questions" buddy, we're all here to learn n help
Old 07-22-2011, 07:47 PM   #18
Yeah if I remember right, there is a little panel on the rear of the lower piece that pops out to give you access to the bolt. Remember the 94ish ones use the Torx screw bolts to hold the seat belt to the floor while the older ones use a bolt. BTW, GM does not stock/sell the seat belts for those years any more. It's hard to find them in the junk yards here as most will cut the beelts on any cars they get in. I am told they are not supposed to sell us seat belt parts, but who knows. Good luck.
Old 07-22-2011, 10:56 PM   #19
cr34t3d_by_d4rkd3n
u wanna jimmy rig something that has to work or else u die? Have u see these trucks in a roll over??
U need to take into consideration degree of bend's of belts, anchor points and how the positioning will change the stress points, u need to understand proper sheet metal reenforcement, how to calculate gforce and other similar tolerances....theres tons and tons of things u need to research before u put in belts....
Never make the seatbelt hold the seat!!!,never use a old mount with a new belt? Thats like mounting new tires on a bent rim. theres my 2 sense.
cr34t3d_by_d4rkd3n is offline   Reply With Quote
