Old 07-19-2011, 01:13 PM   #1
my67c20
Temperature Guage Issues
After installing the motor and using the original wiring harness i kept the temp sending unit in the drivers side head, not wanting to fully trust that i also installed a temp guage in the passenger head. While running the factory guage reads hot and the temp guage reads about 180. My questions is does the factory guage have issues? Is there an issue reading the temp from the passenger head since these heads are interchangeable? This is a new sending unit. I do have a shroud that is about 75% coverage, the bottom section is missing. This appears sitting and driving. My coolant overflow tank is empty and my coolant level never changes. I have no apparent overheating issues. This is a 383 with a manual trans. Any thought appreciated. Thanks
my67c20 is offline   Reply With Quote
Old 07-19-2011, 01:20 PM   #2
cdowns
cdowns's Avatar
Re: Temperature Guage Issues
i always take the temp of the coolant with a known good thermometer to see if a gauge is accurate
Old 07-19-2011, 03:59 PM   #3
JORGIE95961
the sending unit has to be matched up with gauge.. .. lik eth efuel sender.. it has to be set up for correct ohms i think
just what ive heard
JORGIE95961 is offline   Reply With Quote
