Old 04-05-2003, 03:29 AM   #1
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
4x4 suspension ?'s
Ok, I'm kinda lost when it comes to lifts and suspension on these trucks. I'm looking at buying a 4" lift that came off of a 72 Blazer. I'm wondering if it will fit my 72 K-10 and whether or not I've got to lenghthen my drive shafts. Thanks for the help.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-05-2003, 03:54 AM   #2
GreenMystChevy
Well, I am new to the whole 4x4 thing too and am just getting my feet wet. Don't quote me on this but from what I have gathered, the same lift that you use for the blazer is also used for the trucks. Also, I have heard that if you are just running a 4" lift, you don't need to lengthen the driveshafts, but it's good to have longer brake lines.
You might get some more help if you post this in the 4x4 Discussion section. I hope someone else can either confirm or deny my statements.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 04-05-2003, 09:02 AM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
I just did this to my 72. Used the 4" lift kit mfg'd by Tuff Country. It is a very complete kit. I didn't have to lengthen the drive shafts. The kit comes with mounting brackets that extend the brake lines without having to replace them. I didn't use them yet and I might not use them. The rear hose is plenty long and I am not climbing any hills or rocks so my suspension will never see that kind of travel.
I did this on a Sunday and didn't plan to replace the bolts. So make sure you get yourself 6 grade 8's, 9/16x4-1/2 or 5" for the rear springs. They don't carry that size at your average hardware store. BTW, These guys had the best deal I could find www.offroaddesign.com/index.htm
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 04-05-2003, 09:33 AM   #4
meathead95
computer illiterate
meathead95's Avatar
got a pic da-burb
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 04-05-2003, 12:41 PM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
I just might take one today. It is bright and sunny out even if it is only 35 degrees! The ride of the truck has greatly inproved too. Less jarring on the spinal column from the springs.
Old 04-05-2003, 02:13 PM   #6
O'l Buck
O'l Buck's Avatar
thanks for all the good info.......I knew you guys would know.
Chad
