Old 07-19-2011, 02:10 PM   #1
dutsuno
loss of brake pressure, cant be good!
72 c10 1/2ton 350 v8.front disk.rear drums. was driving home last night. turned into my neighborhood. pushed on the brakes. pedal went almost to the floor. i pooped my pants! but the whole drive home, the pressure in the pedal was fine until i was almost home. any ideas of what it might be???? ever since i got the truck, 6months ago. the brake light has been on. my parking brake doesnt work, at least i dont think it does. the parking brake release jus moves freely and the parking brake pedal is up. my master cylinder is filled.
dutsuno is offline   Reply With Quote
Old 07-19-2011, 02:17 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: loss of brake pressure, cant be good!
i would check for leaks at the back side of the M/C ,then check for the brake lines and then rear wheel cylinders for leaks.
got pictures of the master cyl .area ,is it power brakes >?
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-19-2011, 02:31 PM   #3
dutsuno
it is manual brakes. if im looking for leaks in the mc, ami looking for fluid leaking?
brakes
