Old 07-19-2011, 03:51 PM   #1
mjo8585
mjo8585's Avatar
Front/rear suspension parts needed...HELP!!
need some help for these are arm towers and rear coil springs mounts. please help!!
mjo8585 is offline   Reply With Quote
Old 07-19-2011, 04:35 PM   #2
creepdogg
Re: Front/rear suspension parts needed...HELP!!
Looks like you need yourself a new ft Xmember, you could check Junk yards for an entire assy from a 71-72 or even a 73-87 depending on what your wanting to do with the ft end, Im sure others can chime in. On the rear looks like you may need to find a donor frame. I wonder if some Porter built components would help you out, or even a Cnotch kit from CPP ????
I got a leafer frame for sale, but that wouldnt help you.
creepdogg is offline   Reply With Quote
Old 07-19-2011, 05:29 PM   #3
Monty
wish i woulda known...i'm swapping out my 2wd Sub running gear for 4x4 and i gave the front cross member away to a guy looking to upgrade his drum brakes.
if i have to remove the rear coil spring mounts, i will save them for you.
Monty is offline   Reply With Quote
Old 07-19-2011, 05:31 PM   #4
creepdogg
Hmm, u know, I may have what your looking for on the rear, I am replacing my rear with a Porterbuilt Stage 2 with cnotch and new trailing arm mounts with new xmembers. Shoot me a PM, my parts wont be arriving for about 2 weeks. But I may have what you will need.
Old 07-20-2011, 02:19 PM   #5
tkeduk8r
tkeduk8r's Avatar
Got your message.. pm sent!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 07-20-2011, 02:32 PM   #6
robbieg454
I have a complete frame roller. 2wd.
robbieg454 is offline   Reply With Quote
Old 07-21-2011, 08:42 AM   #7
72ArizonaBurb
I have a complete 5 lug front suspension that I would need to destroy to get these off for you. What price did you have in mind?
72ArizonaBurb is offline   Reply With Quote
