vapor lock
what is the cheapest way to eliminate vapor lock? ive been told a 2 inch spacer should do the trick. ive got a 454 with custom radiator. never had a promblem before, but it did happen. thanks for the help.
Re: vapor lock
Electric fuel pump installed as close to the tank as possible.
and a few others
Re: vapor lock
The cheapest way? Take old style wooded clothes pins and clip them on your fuel line between the pump and carb. 4 or 5 of them if possible.
Old school remedy that really works. No joke. The wood dissipates the heat and stops vapor lock.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
It's Better With Nitro
Re: vapor lock
Are you getting vapor lock in the carburetor, or somewhere along your fuel delivery line? Yes, if fuel is boiling in the carburetor, a phenolic spacer will help. If the vapor lock issues is somewhere along your fuel line, you'll have to identify where the hot spot is and either reroute your line, install a heatshield to block the heat, or a heat sink to dissipate the heat.
Senior Car Nut
![]() Join Date: Jan 2008
Re: vapor lock
Larry |
Who Me?
Re: vapor lock
Yep!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
