Old 07-19-2011, 07:30 PM   #1
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Oil Filter Differences (6.0L)
I did a search and cam up zip, zilch... na-da.
2006 Chevy 2500HD with the 6.0L Engine. Looking at oil filters for when I change the oil. There is an AC-Delco PF-46E on the 6.0L right now. Was on there when I bought it at the dealer last month. So I was at my local parts counter (which is a mom and pop store with good knowledgeable people backed by Parts Plus), and asked them for an AC-Delco filter for my truck. She comes back with a PF-61E. Says that's all that the computer lists. I tells her that the truck has a PF-46E on it. Now the gals that work at this place know their stuff... so she was stumped as to why the PF-46E was not showing up for the truck, and only the PF-61E was.
Looks like the PF-61E will fit my truck. It is a smidge longer than the PF-46E. But after she and I did a little research it appears that the PF-61E has no "anti-drainback valve" in it where the PF-46E does. Soooo...
What the heck? What is this "anti-drainback valve" monkey motion, and does the 6.0L have this feature? My oil isn't due to be changed in a bit... so if I have to order a PF-46E I can. No biggee... but I like to support my local businesses when I can. Been going to this parts store for 20+ years.
Anybody got any info to share?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-19-2011, 08:40 PM   #2
truckdude239
truckdude239's Avatar
Re: Oil Filter Differences (6.0L)
i don't know about the ac delco filter but the puratlor for that truck is a l14006 but the l25288 is the same filter just longer
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-20-2011, 12:51 PM   #3
biggsteve97
the anti drain back valve is designed to keep oil in the filter when the engine is shut off. however, since chevy runs the filter in a position where the fill hole is on the top the drain back valve really serves no purpose. you can run either filter just make sure the threads are exactly the same and the diameter of the o-ring is the same.
biggsteve97 is offline   Reply With Quote
