Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-19-2011, 07:57 PM   #1
73gmc454
73gmc454's Avatar
electrical question
not sure how to explain this or if its in the right spot but I'll try , I'm using air soleniods to operate my air ride and horns ,these are producing stray voltage that is making the led lights on my dash flash when you hit the switch to turn the solenoids on or off, after some research I have found I may need a metal oxide varistor or mov , has anybody ever had any problems like this or fixes ?
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 07-19-2011, 08:13 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: electrical question
im going to move this to electrical for a better response.. if that doesnt work let me know and we can try suspension....you could also shoot a PM to N2Trux as i think hes fluent in this kind of stuff
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 07-19-2011, 08:28 PM   #3
73gmc454
73gmc454's Avatar
Cool thanks, I've been going crazy trying to figure this out ,
Old 07-19-2011, 09:16 PM   #4
fixit-p
fixit-p's Avatar
Do you have a diagram of how this is wired? Your description is kinda vague, what are the led lights you refer to, are they on already, what controls the led's? Collapsing coils can create a voltage spike but in the circuit you describe if wired correctly wont be a problem because when the coils are collapsing the switch state is open which would isolate other circuits.
You can use diodes across the coils but again in this simple circuit it really shouldn't be needed.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-19-2011, 11:21 PM   #5
73gmc454
73gmc454's Avatar
Thanks for the reply and the help, I'll try to explain more , its a 77 gmc ,as for the dash lights , I removed the the gage cluster and and made my own, I wired the turn signals, bright lights and low brake light wires in the leds as they were hooked in the cluster from the factory grounds and all , the circuit for the solenoids is on it own wired to the battery fused with a 30 amp circuit breaker, the 2 solenoids that run the air ride have a positive hooked up to a 50amp switch which runs to the solenoid and they are grounded to the frame near the solenoids ,
The horn is hooked up to the factory button on the steering wheel that grounds when you push the button ,so I ran that as a trigger wire to a relay that get its power from the same circuit as the other solenoids , I ran the power to the horn solenoids from the relay and ran the ground to the frame close by,
I get the lights to come on for a split second when I switch the air solenoids on or off and when the horn button is pushed, the key doesnt have to be on for this to happen since its on its on circuit I figured, I can understand the horn because it on with the factory circuit but not sure about the air ride solenoids , but if I just plug a 194 light socket with light into the air ride solenoid wires instead of the solenoid it does not flash the leds , but again if I do the same with the horn solenoids it still flashes the leds , I figure it must be because of the relay ? thanks again , Jamie
Old 07-20-2011, 01:41 AM   #6
fixit-p
fixit-p's Avatar
First thing I would do is verify and upgrade your grounds (more on this later), what I suspect is happening is that you have adequate power supply to the solenoids and the solenoids maybe grounded to the frame but the frame is not providing enough continuity back to the batteries negative terminal. If you have a 30 amp draw on the positive terminal, that 30 amps needs to get back to the negative terminal and when it can't it will seek out alternate ground paths, in this case I suspect from frame to cab to cluster to leds' to ground. Same thing with the horn, the horn relay has power through the coil and to the horn button when you press the horn button it is supposed to sink to ground but if the cab is not grounded then the cab will also have power present and it will seek a ground path through any circuit connected to it. To test the condition of your ground use a volt meter with the positive lead connected to the ground wire of the solenoids and the negative lead connected directly to the batteries negative terminal, actuate one of your air ride switches and any reading over .2 volts indicates a faulty ground. Never use a continuity test to test the condition of your grounds because the results will be misleading.
