Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-19-2011, 09:04 PM   #1
1968CHEVYC10
1968CHEVYC10's Avatar
Temp Gauge not working
Well I think the gauge may not be the problem, but it never moves when I'm driving it. the gauge will peg hot when I ground the wire, So I replaced the temp switch, didn't fix it. I tested the temp with a multimeter, put the +lead on the + side of the batt, then the -lead on the spade connection on the temp switch, read 12v. From what I've read this means the switch is short circuited and no good, but then shouldn't gauge peg hot when ever the wire to the gauge is hooked up? It doesn't.
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 07-20-2011, 02:17 AM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Temp Gauge not working
Gunna move you to electrical...maybe they can help.
ETsC10 is offline   Reply With Quote
Old 07-20-2011, 06:54 AM   #3
panhandler62
Java Mechanic
panhandler62's Avatar
Check impedance from the spade to a good engine ground both hot and cold and see what you get.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 07-20-2011, 08:46 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
check this site.
http://www.6066gmcguy.org/Electrical-02.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
