Old 07-19-2011, 10:03 PM   #1
swierker
swierker's Avatar
Question Easy way to remove inner fenders
What is the easiest was to remove the inner fenders? Or basically can it be done without removing the outers?
Dan
1970 Chevy LWB - 305/350
In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's.
swierker is offline   Reply With Quote
Old 07-19-2011, 10:05 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Easy way to remove inner fenders
Unbolt them, jack the truck up and remove the front wheel. It will drop out.
Old 07-19-2011, 10:49 PM   #3
dubds10
Stalker Nate
Just hope the square clips which the bolts are threaded to don't break off. Otherwise it'll take a bit longer lol
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 07-19-2011, 11:17 PM   #4
72lb4x4
Yep. Its a good idea to loosen a little, tighten a little, and repeat until the bolts come out.
72lb4x4 is offline   Reply With Quote
Old 07-19-2011, 11:53 PM   #5
blkcorvair
blkcorvair's Avatar
just took mine off tonight. (with the outer on) used a mapp torch to heat each bolt first. (Helped to soften the Undercoat and sit the socket flat) also use a 6 point socket so you dont start to round em out
blkcorvair is offline   Reply With Quote
