axle to bottom of frame hight
i really need the measurements from the top of the axle tube to the bottom of the frame on a stock truck, i cannot figure out how low mine is in the rear and this may be a good place to start.
thanks all
Re: axle to bottom of frame hight
If you don't get measurements by morning, I'll pull them for you. Mine is a 2wd short bed if that's what you're looking for.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
#3 | |
My truck has no drop yet and it measures 9.25" from the top of the axle tube to the bottom of the frame. There is about 100lbs of weight in the bed and the fuel tank only has about 3 gal of fuel in it. Hope this helps.
My measurements came to 4.75 inches from tube to frame,
Ane there any ways to accuratly measure the front suspension? Posted via Mobile Device
Could measure from the ground to the bottom of the front cross member, then figure out the difference in tire size between yours and mine.
| Bookmarks |
