Old 04-05-2003, 11:24 AM   #1
go-fast69
? on lowering
I have a 69 GMC that I want to lower as much as I can (can't afford air bags though). My question is this; how much can I go in the front and back and what is the best way to do it? Thanks.
69 swb GMC, 402 BB, 3:73 posi, 3" exhaust, forever a work in progress
go-fast69 is offline   Reply With Quote
Old 04-05-2003, 11:36 AM   #2
ocbaud
Garage Queen Material
do you have coil or leaf rear-end? what size tires are you gonna be running. full headers?
with a 4/6 drop on my truck, my collectors are about 3" from the ground.
ocbaud is offline   Reply With Quote
Old 04-05-2003, 05:13 PM   #3
go-fast69
ocbaud, I am running P275/60R15 with full headers and a coild rear end. Your post says you have a 4/6" drop. Is that 4" front & 6" rear? Thanks.
Old 04-05-2003, 06:48 PM   #4
sbc350gearhead
sbc350gearhead's Avatar
if you want the lowered look of a 4/6 drop fine. but for maximum ride and handling, Hotchkis performance says a 2/3 drop is optimum.
sbc350gearhead is offline   Reply With Quote
Old 04-06-2003, 02:56 AM   #5
ocbaud
maximum ride and handling? my truck rides lots better then it did at stock height and i'm sure there are many people that will agree on me that my/or anytruck handles better with a 4/6 drop then it would with a 2/3 or 2/4 drop. thats because i have a lower center of gravity allowing for better handling at higher speeds with less body roll.
Old 04-06-2003, 03:00 AM   #6
1FaastC10
1FaastC10's Avatar
Eric is right, anybody with any common sense knows that lower CG = better handling.
1FaastC10 is offline   Reply With Quote
Old 04-06-2003, 03:00 AM   #7
ocbaud
i'm running 275/60/15's too, but not for long. for about the first week after i dropped my truck, my fender lips would shread my tires up(not really that bad though). so i had to roll the fender lip up with a bat, and that helped a lot. i'm gonna be getting 255/60/15's all around sometime though. i have full headers and they are about 3" from the ground with my drop(4" in the front, 6" in the back)
Old 04-06-2003, 09:55 AM   #8
sbc350gearhead
I am not a mechanical engineer.....the information i gave is a quote from a car craft magazine article where hotchkis performance changed the suspension on a 98 tahoe for top handling and stability. I do not know why a 2/3 drop is better. but i have to believe information from the premier lowering equipment manufacturer.
Old 04-06-2003, 10:22 AM   #9
go-fast69
Thanks for all the information, should give me an idea so I can get started.
Old 04-06-2003, 01:58 PM   #10
CustomChevy
Hotchkis is probably referring to optimum handling and ride both. lower center of gravity will absolutely give better handling, but if you decrease the amount of travel available in the suspension too much, the ride quality will absolutely decrease, giving you the wonderful "bouncy" effect that Hotchkis is wanting everyone to avoid.
of course, personally I would prefer 4/6.
CustomChevy is offline   Reply With Quote
