Old 07-20-2011, 07:58 AM   #1
NicoSlam
Tach dash issues
I just realized that my original tach dash stops at 2500rpm. Does not look like any physical damage. The truck can be further reved but the tach makes a clean stop at the rpm. Does anyone have any idea. The tach dash originally came with an air pressure gauge instead of vaccum. Thanks
NicoSlam is offline   Reply With Quote
Old 07-20-2011, 07:53 PM   #2
Dave
DND Trucks
Smile Re: Tach dash issues
Your going to have to remove the dash from the truck. And then the tach from the instrument case. Once removed, using compressed air in a can, carefully blow air around the tach meter path of travel. It's possible there could be some debris lodged in this area. You may want to use a safe electronic board cleaner in addition.
Also, if you own or have access to a ohm/volt meter you could check to see if the tach meter itself is ok. If you don't know how to test it, lmk and I'll tell you.
Dave is offline   Reply With Quote
Old 07-20-2011, 10:48 PM   #3
Sammy
Dave my tach only works when it wants too, lately it just quit all together. Been thinking about tinkering with it but other issues always seems to get the attention first. Any ideas besides the plug connection on the rear? I will reseat that plug first incase its a simple connection thing.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-21-2011, 08:24 AM   #4
Dave
DND Trucks
Sammy,
Your right, check all connections first. If no change, your going to have to do the same. Basically, remove tach from the instrument case and perform the above steps. I can explain in furthur detail how to check the tach a ohm/volt meter. Generally, often times it's something simple. LMK.
Old 07-21-2011, 08:46 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by Dave View Post
Sammy,
Is this something that you can explain here?
Keith
Convert to disc brakes.
Old 07-21-2011, 09:50 AM   #6
NicoSlam
thanks for the help. I removed the tach and confirmed that the needle travels freely from 0 rpm to 5000rpm which tells me its not a mechanical issue although when I drove the truck and first saw this issue, it made a dead stop at 2500rpm implying something mechanicall was holding it back. Anyway, can you explain how to check with the ohm meter? It dont believe the issue is electronic only because it functions properly and accurately between 0-2500 rpm. No bounce etc. but it has to be mech or electrical so I'll try anything twice. thanks again
Old 07-21-2011, 09:53 AM   #7
Dave
DND Trucks
Keith,
I'm probably need to get some pic's, showing where to place the meter leads, etc. Just a quick check of the meter assembly it what I had in mind.
Old 07-21-2011, 03:16 PM   #8
Dave
DND Trucks
Nicoslam, pm sent.
Old 07-21-2011, 10:43 PM   #9
Dave
DND Trucks
PM's sent to everybody. LMK, if you have any other questions.
Old 11-04-2011, 11:55 PM   #10
-sean-
Any update on this? I am having the same issue, stops dead at 3700 rpm.
-sean- is offline   Reply With Quote
Old 11-09-2011, 01:44 AM   #11
Dave
DND Trucks
Do you have an Ohm meter? PM me when you get a chance.
