Old 07-20-2011, 01:43 PM   #1
pig rig
pig rig's Avatar
max lift
a friend of mine's dad has a 77 1T dually that he bought new thats been setting in their barn for more then 10 yrs. well with some sweet talking I'm going up to get it this weekend.
I've been throwing around the idea of building a 4wd truck for a couple years now. Ive got it all mapped out in my head of what I want other then 1 small detail how much lift do I need to get 38" tires under it? I'm kinda wanting to not go much bigger then 6" can a 38" tire fit with only 6" lift or would I have to go to a 8" lift? I'm thinking with the front wheel being the bud type it would bring the tire in enough that it will clear the wheelwell lip at the bottom where everyone cuts it to make a to big of tire fit
so give me some advise on this
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 07-20-2011, 02:01 PM   #2
ncgamedog
Re: max lift
Are you gonna keep dual rear wheels or convert to SRW in the back? I'm assuming this truck is just for pretty no offroad? I ran 42's on my 78' k5 with 4" lift and minimal trimming...It was also on tons. IMO anything over 6" is tacky and pointless, i.e. serves no function. 6" raises the COG too much for my taste, but others have gone that high with success.
But, based on my original assumptions, and to answer your question...
6" should clear 38's.
That is just a rule of thumb, there are lots of other factors to consider...Which 38? a TSL? TSL's run small in the 38 so they def will. 15.50" wide one will prob rub the inner wheel well or springs, but that also depends on wheel offset, wheel width, and back spacing.
ncgamedog is offline   Reply With Quote
Old 07-20-2011, 03:39 PM   #3
Mr. 250r
Mr. 250r's Avatar
Re: max lift
I run a 4in suspension 3in body and 38.5 tsl no rubbing and no fender trimming only time they rubbed was when I went up a hill and smashed my front down very hard it pushed the back bottom part of the front fender up a little but it will take about 5 minutes to fix when I get around to it, ill get exact wheel and tire specs tonight
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 07-20-2011, 04:37 PM   #4
Prerunner1982
Prerunner1982's Avatar
Re: max lift
Here is a members truck (ARAMP1)..it only has 4" lift and 33" tires. but thought I would post it anyways. It sits about 3" higher now though as he is putting a Detroit 4-71 under the hood.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 07-20-2011, 05:16 PM   #5
pig rig
pig rig's Avatar
Re: max lift
ncgame your right I'm not planning on doing any 4wheelin with it. I want it mostly for running over the passes in the winter (I'm tired of being stuck in the snow up there). I'll leave it with drw's just because I like big butts. and I was thinking any thing more then 6" is to much if I knew for a fact that I could get away with only going 4" I would.
Old 07-20-2011, 08:01 PM   #6
b454rat
Re: max lift
Just remember whatever lift you put under it, add 2" for the frame height. 1 tons have a taller frame so 4" spring lift will give you 6". My crew has about 8" of lift and the axle is moved forward, trimming the front fang of the fender should clear 40s....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 07-20-2011, 11:24 PM   #7
ghettoluxury
ghettoluxury's Avatar
Re: max lift
You should clear 38's with 6". I am running 35x13.5 with 4" on my crew and no rubbing. If you yant to go cheaper get 4" front spring and shackle flip in the rear with a 3" body lift.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 07-22-2011, 01:27 AM   #8
pig rig
pig rig's Avatar
Re: max lift
it wont get a body lift I hate body lifts. I got a better look at this thing today its got a 454 with the 4spd with the granny 1st I didnt say in my first post but its a std cab pick up. so it should make a nice truck to run around in in the winter
Old 07-22-2011, 09:50 AM   #9
ghettoluxury
Re: max lift
Here is 35x13.5 with 4" front springs and rear shackle flip, on my crew.
Old 07-23-2011, 09:44 PM   #10
Tex_50613
Redneck Customs Bumpers, IA
Tex_50613's Avatar
Re: max lift
that's what I'm running on my 85 the 4" and 3" body and have 44's with trimming and ran 38.5 TSL-sx with minimal trilling to the lower rear of the front fenders
with the 38.5's and the 76 front clip
Overkill is under rated, Redneck Customs Truck Club Hudson, IA
"Clifford" 83 Chevy K20 4x4, Mudder 7" lift rolling 44's
"Basterd Child" 86 Chevy K30 4x4 crue cab Dule, 7.3l international WIP
'00 ex-cab Silverado 4x4 DD
I hate red trucks but you can't tell by looking at what I own
Tex_50613 is offline   Reply With Quote
Old 07-24-2011, 12:17 AM   #11
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: max lift
What kind of wheels are you going to run? almost all factory and most aftermarket Budd type wheels are only 6" wide. I know I've seen guys run that large of tire on a dually but not sure how they do it...most all 35" and above tires are fairly wide..and even then I would think you would have to run a spacer of some kind between the rears to space them apart.
I had 19.5 8Rs on my dually and they measure just over 35" with a 4" lift..had plenty of room on the front but the rears were pretty close to the fenders.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 07-25-2011, 10:31 AM   #12
Burt4x4
Burt4x4's Avatar
Re: max lift
Hell'Ya!
Years ago SuperLift Superride had a 5.5" lift kit..all spring kit no blocks...I run the rears in my K5...anyway might be perfect..assuming too that the 38s yer after are not going to be super-wide but tall-n-skinnier?
Here is what 8" Alcan lift looks like..not sure how tall the michelins are, 11.00R16 whatever that equals too?
Get some pics posted!!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
