07-20-2011, 02:05 PM | #1 |
3 speed to TH350: Shopping for correct Yoke
So I am going to convert my 3 speed to a TH350. I am trying to find the correct Yoke for my 71 3 speed drive shaft. This is the first time I am doing this, not sure it uses outside or inside clips. I inquired on ebay and got this back from a seller:
The 350 yokes comes in many different u-joints and lengths.Does the joint in the shaft use inside or outside clips.If outside we need the cap dia and joint width.Also what kind of vehicle did the trans come out of. does anyone know which type of yoke i should get? |
07-20-2011, 02:12 PM | #2 |
Re: 3 speed to TH350: Shopping for correct Yoke
When i did mine i thougt i had th right one.. The driveline shop swaped me and got it right
07-20-2011, 02:27 PM | #3 |
07-20-2011, 02:34 PM | #4 |
07-20-2011, 04:48 PM | #5 |
Fabricate till you "puke"
Count the bolts on the side plate on your 3spd(should be 7, if original)....if thats the case, you have the proper slipyolk already, & the drive shaft is the proper lenght ,for a short(6" tailshaft 350 hydro). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-20-2011, 04:51 PM | #6 |
REALLY I HAD THE SAME SETUP, never counted the bolts.. and it was totaly different if h.. wait mine was a 4 speed.. nevermind
07-20-2011, 08:43 PM | #7 |
really? i thought i had to change the yoke. it is the original 3 speed i have in there. thanks, this would be awesome if i don't need to change it
07-21-2011, 07:16 AM | #8 |
Watch out for your cornhole !
Same yoke
07-21-2011, 09:17 AM | #9 |
Rottenwood Garage Member
I also think its the same...try sliding it in. If it needs to be shortened it should be no more that $50 including balancing. Lengthened it will be about $150. Just type in Driveshaft Services for your area...there will be something.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
07-21-2011, 02:55 PM | #10 |
They are probably the same but the 3 speed has a vent hole in the plug at the end of the splines. It should be welded shut.
07-21-2011, 07:48 PM | #11 |
Sorry to Hyjack the thread. But since this came up does the TH350 Fit in the low hump tunnel? Or does it need the high hump? Thinking of the same conversion.
07-21-2011, 07:54 PM | #12 |
Th350 fits under low hump fine. That's the standard configuration the factory did when they were new.
07-21-2011, 11:30 PM | #13 |
Sisyphus was my mentor!
Changed my L6/3 sp to a smallblock/700r4 last week & I was able to use the same yoke & same driveshaft length.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
07-22-2011, 10:54 AM | #14 |
thanks for the help, plan on doing this soon!
