Goodmark replacement door
I wondered if anyone has used a goodmark door on a 67-72 chevy truck with any luck. I want to know about fit and quality or does anyone have a very nice OEM door that they want to part with.Thanks for any help Rick
Rottenwood Garage Member
Re: Goodmark replacement door
It is my understanding that NONE of the doors available in aftermarket are a good fit. Im sure the ones in the know will chime in soon.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
![]() Join Date: Nov 2005
I used both sides on mine. There not bad, but need some tweeking to get a decent fit. They will never be as good as orig. but there better than beat-up rusted ones. I had to cut the top window frame off my old door and weld on to new one to get a good fit. The pass side fit pretty well though. Good Luck!!
![]() Join Date: Jan 2008
I have one on my 68, and I will never use an aftermarket again! Money will be well spent on finding a nice original! .02
![]() Join Date: Apr 2007
Let me tell u where the problem lies--if u look at an oem door the window frame in the upper curve NARROWS thru the curve---the aftermarkets stay the same width all the way thru the curve--big problem!! took me a while to figure out but when u look close it's obvious-- jim
![]() Join Date: Sep 2009
Hey Rick, which side do you need? We have a nice pair of doors with factory paint, no bondo, no extra mirror holes but they do have speaker holes.
Hope that helps Paul They may move this to the parts section because it has evolved that way
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
I need a drivers door Thanks
Thanks For all the responces I think Ill keep looking for an original Rather not deal with speaker holes. Thanks Rick
![]() Join Date: Mar 2000
The previous doors available were good in some instances and bad to extremely bad at other times. Some would bolt on no problem others needed various portions re-worked by drilling out spot welds and re-welding upper door window frames correctly to the lower door shell, undoing strap holding inner door to outer skin and re-setting it at correct width then rewelding it and others were a total nightmare to get corrected due to poor jig set-up then being welded together causing them to be distorted in belt line gaps, outer to inner skin being aligned incorrectly, etc.... However the same can't be said for the new door shells that are out now in the last year or so the previous door shells available were hit and miss on quality but the new versions appear to be right on the money and after trying them then selling a few dozen to people who bought the old versions from others and receiving stellar feedback from them when compared to the other brands available we are now very happy to offer the Highest Quality doors that actually fit like OEM. Currently the 67-71 are in stock and the 72's which are out of stock are due back in at the end of this month.
Paul Jr @ GMCPauls |
![]() ![]() Join Date: Dec 1999
I have a bunch of rustfree drivers doors. Here in Ohio.
Give me a call 937-408-1404
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
#11 | |
Sounds like these may be a good option....Looks like we have a vendor that has tested and stands behind them!!! I would say if the shipping was guarantied to be refunded both ways if they were not a perfect fit...GO FOR IT!!!
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 07-21-2011 at 11:22 AM. |
My Goodmark doors have same problem with the window frames. Passenger was good but the drivers window frame has to be cut off and welded on differently. Also one if the holes for the vent window was drilled at wrong place on drivers door. Good luck!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
Tags |
ricks 1970 chevy truck |
