Moderator
![]() Join Date: May 2007
Is there any difference between a 72 rear end from a 2wd truck and a 4wd truck, other than 2wd being coil sprung and the 4wd being leaf sprung? I am looking at buying a rear end from a 72 4wd truck to swap into my 72 2wd truck. I know the 4wd has six lugs, but I am thinking I can swap my 5 lug axles into it because they should be the same length. If so, how hard is it to convert from leaf spring to coil spring perches? Thanks in advance.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Always on the hunt...
![]() Join Date: Sep 2006
Re: Differences in a 72 4wd and 2wd rear end
Hi Scott, sounds like you have a pretty good understanding already on what is different. When talking 71-72 leaf to leaf rear end swaps, the C/K series rears had different spring pad widths, except for the longhorns which are a direct match on the spring pad width to the factory K rears.
When talking leaf to coil rear swaps, the main issue is going to be the cutting/grinding/welding of the spring pads & converting over to the trailing arm type angled mounts. You will also need to add a super track bar kit also since there is no provision on the leaf rears for a track bar, since the K rear is a 72, your 5 lug axles (if oe) will slide right into that 12 bolt K housing & diff. Mel ![]() |
Restoration Virgin!
Scott...not a how-to but I think TX Firefighter has explained it here
looks like ya gotta match up the pinion angle and weld on the coil spring perches ![]()
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Moderator
thanks for the info guys!
mel- i had forgot about the 4wd rear not having a mount for the panhard bar. i have an adj. bar already and do not want to buy the deluxe. geoff- thanks for the link. getting the pinion angle right is critical, especially with a 7" drop. more time than i wanna spend, so im gonna pass on this one and keep looking for a 2wd coil sprung rear. Posted via Mobile Device
Restoration Virgin!
I got one sitting out in the shed over here on the right coast!!!
Moderator
too bad i am on the wrong coast, lol
#7 | |
I too will be looking for a 2wd coil rearend and getting rid of the leaf.
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
