Stepside bed
Does anyone know if the stepside beds from early 60's trucks or 73-87 trucks the same as the ones for 67-72? I know the fenders are different, but i'm wondering about the bedsides. I know that the tail gates are the same for the 73-87's. Thanks Josh
Old Skool Club
![]() Join Date: Jun 2001
Re: Stepside bed
With all of the bed-swapping I've seen over the years, I see no reason that you couldn't use the earlier bed, and install the correct fenders for your truck. I know the fenders changed in '73, and that they were different from '55 (second series) thru '66, when they changed. So, I see no reason to be worried.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: Stepside bed
I think the 73-87 bed are a bit different, check the FAQ's there's a thread in there about putting a 73-87 step on a 67-72, I remember it didn't just bolt in, some slight modification was necessary.
'68 C10 LWB 6.2NA/NP833 3.73's |
Re: Stepside bed
Thanks guys, I'm in need of a new bed and the 67-72 are hard to come by around here. Hoping the 73-87 will work. Thanks Again
![]() Join Date: Jan 2008
Re: Stepside bed
A 73-87will work, but you have to add a section to the front where the step bolts on, and you also have to re-drill fender mounting holes, and re-fill the old ones. I purhased new Mar-K bedsides a few years ago for about $350 each with the polished stainless strips. They were spot on to oem specs. Money well spent, and you don't have to do all the body work. I did add a reinforcement into the rear stake pockets for taillight mounting. Good luck.
Re: Stepside bed
the beds are the same along with the tailgates ... the only difference is the steps and fenders. you can redrill the fender mounting holes and you are good to go.
Re: Stepside bed
I will disagre with you. The step on the newer beds sits up higher on the bed, therefore you have to add a section to mount an early set of steps.
![]() ![]() Join Date: Jul 2002
Re: Stepside bed
The beds from 47 to 87 are the same dimensions. Where they differ is the front side panels where the steps mount and the rear cross brace. AS long as you take the bed with all the same year attachments (fenders & steps) it is pretty much a bolt on.
However if you want to use a 73 up bed on an older model or vice versa, the bedsides where the steps mount is different. the 73-87 do not drop as low, so you'll have to modify it for the older beds. to go the otherway you will have to shorten the step mounts. I did the board writeup on how mine was done taking an 84 bed and making it work on my 70. http://67-72chevytrucks.com/vboard/s...d.php?t=123833
Re: Stepside bed
Re: Stepside bed
dont know hat type bed this guy has but it's in florida
http://tampa.craigslist.org/hil/cto/2478915777.html
Truck Parts Mfg.
![]() Join Date: Jul 2005
Re: Stepside bed
There are a lot of differences from one series to the next. Some are subtle, some are significant. This article discusses these differences. http://www.mar-k.com/bed_side_interchange_gm.html
Hope this helps Mar-Ktech
GET MAR-K Quality! Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks |
