Old 07-20-2011, 09:30 PM   #1
grs
C-Notch 87.
I need to cut a small part out of a brace that goes across the bottom of the bed. The c-notch won't slide under the bed. How do I cut it out without removing the bed? I don't think I can get a torch in the area. It is an 87.
grs is offline   Reply With Quote
Old 07-20-2011, 10:24 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: C-Notch 87.
Can you just loosen the bed bolts and then just block the bed up with 4x4's or something?
No need to take it completely off.
Keith
Convert to disc brakes.
Old 07-20-2011, 10:39 PM   #3
grs
Re: C-Notch 87.
I thought of doing that. That may be my winter project.
Old 07-21-2011, 10:49 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: C-Notch 87.
Like lolife99 you can unbolt the bed and lift one side at a time by yourself. It's much easier if you remove the bed completely as long as the bolts aren't rusted. Either way, I would raise the bed before cutting a brace above the C-notch
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-21-2011, 05:27 PM   #5
grs
Re: C-Notch 87.
Thanks, that will be my winter project.
