Old 07-21-2011, 01:08 AM   #1
TrkEnvy
Rear quarter panel cap
Hello from the 67-72 side of the forum.. I have a question in regards to my dads 66 c20. It was rear ended and pushed the big steel bumper on one side into the rear quarter panel end cap and pushing the quarter up and in.. We are wondering how do we remove the cap from the bed side?? Do I have to take the whole thing down and take it off or can I do it with it still mounted on the truck??
TrkEnvy is offline   Reply With Quote
Old 07-21-2011, 01:22 AM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: Rear quarter panel cap
What is the cap? Upper bed side or front roll pan? Pics?
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 07-21-2011, 01:39 AM   #3
TrkEnvy
The end piece that houses the tail light lens. It looks like a cap on the rear attached to the bedside. It is removable right??
Old 07-21-2011, 01:46 AM   #4
TrkEnvy
This part... How do I remove it so I can repair it and pull the bedside down and out???
Old 07-21-2011, 01:56 AM   #5
Slow Build
Slow Build's Avatar
Just looking at the one on my parts truck I'd say it seems to be welded around the exterior parimeter (someone else beat it up so I don't know if they were just spot welds or not). There doesn't look like there was any welding on the tailgate side. I'm sure somebody else has more info.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 07-21-2011, 02:03 AM   #6
TrkEnvy
Thanks Slow.. I took too bolts out in the lower section today from underneath and looked for spot welds but I was having trouble locating them. The truck is super clean (no rust) so I dont wanna have to pull off the whole bedside to fix this one area.
Old 07-21-2011, 02:10 AM   #7
Slow Build
Slow Build's Avatar
Here are a few more shots.
Past GM Trucks:
Old 07-21-2011, 03:03 AM   #8
1964c-10
1964c-10's Avatar
it is spot welded all the way from the edge above the tail gate chain bracket down to the bottom of the quarter panel. i removed mine by taking off the tail gate chain bracket then running a cut off wheel all the way around it. then all the spot welds are accessable, and hit them with a spot weld cutter to remove the rest of the piece.
2003 Serria K1500
1998 Camaro
1964 C10 long fleetside bed, small back window, 3 on the tree
1964 C20 custom cab, long fleetside bed, big back window, 4 on the floor
Disclaimer- anything posted is only based on my personal experience, opinions, and advice given by others. There are no implied or written warranties or guarantees with anything posted on this website.
1964c-10 is offline   Reply With Quote
Old 07-21-2011, 08:05 PM   #9
Sillyoldman
#16876
OK I gotcha. Yes as stated they are removable. Unfortunately I snagged mine on a fence and removed it by accident. I ordered a new on. It's going to take a little work to make it fit though. I'm considering riveting it back on since I do not have a spot welder and access is limited without removing the bedside.
Old 07-21-2011, 08:56 PM   #10
ralf
I would cut away the crumpled part to get to the spot welds easily. A good Blair spot weld cutter is the tool for the job. You can drill holes and plug weld the new piece.
ralf is offline   Reply With Quote
Old 07-24-2011, 08:50 AM   #11
awbrown
My question is , how would anyone access the inside area to spot weld the new one on??? I replaced the whole bed corner/post and I got to looking at it and figure the factory must have had some weird spot weld rig to get up in there....
awbrown is offline   Reply With Quote
Old 07-24-2011, 10:46 PM   #12
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
the best way to re-attach a repro or repair one is to use panel bonding glue..that is if you want to keep the factory seam.
it is spot welded on, and there is no way to get at the spots without either destroying the bedside or cap...
