Old 07-21-2011, 11:47 AM   #1
Macs66-C10
Macs66-C10's Avatar
66 Brake Booster - fix or replace?
Finally drug the '66 out of the field and fired it up after several years...still runs great. So now going through the brakes...drums all around, need new shoes, cylinders, master cylinder, and a couple of lines.
When I took off the master cylinder, the rod that goes into the booster is fused (rusted) into the MC. So I started looking at replacing both the MC and the booster. I am having a hard time finding a booster.
Should I try to fix mine or replace everything with a more modern setup? I could try to remove the rod from the back of the MC but it does not look good...and I don't know if there is any kind of clip or anything that holds that rod in the MC. If not, I may be able to get it out.
And if I replace everything, I will probably want to go the extra mile and put discs up front. A lot of expense, but probably worth it.
Any suggestions on either fixing my current setup or options to replacing with a different setup would be appreciated.
Macs66-C10 is offline   Reply With Quote
Old 07-21-2011, 01:53 PM   #2
Macs66-C10
Macs66-C10's Avatar
Re: 66 Brake Booster - fix or replace?
I think we can rule out the possibility of fixing the MC or the booster...I took them to a mechanic and he said the booster will need to be rebuilt or replaced.
So, plan B - what are my best options for replacing the booster? I wonder if I could use one from a '67-'72 with minor modifications...
Old 07-21-2011, 02:39 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
you could use one from any 1/2ton gm truck, there is a guy here that sells an adapter plate to s=connect them to your truck, I think it is Captnfab.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-21-2011, 02:54 PM   #4
Macs66-C10
Macs66-C10's Avatar
Looks like a great option...thanks!
Old 07-22-2011, 01:27 AM   #5
jocko
jocko's Avatar
here it is.
http://67-72chevytrucks.com/vboard/s...d.php?t=347484
Old 07-22-2011, 11:30 PM   #6
Captainfab
60-66 Nut
That's the one for the '67-'72's
Here is the for sale thread for the '63-'66's
http://www.67-72chevytrucks.com/vboa...=1#post3257836
Macs66-C10 has one on it's way to him. Thanks guys
