Old 07-21-2011, 05:15 PM   #1
bruin_d
bruin_d's Avatar
one odd question one normal one...
The odd one...
How long of a coil wire can I get away with running?
The not so odd one...
Does someone make an adapter to go from the horseshoe type to the pedestal type carrier bearing?
Thanks in advance.
bruin_d is offline   Reply With Quote
Old 07-21-2011, 05:33 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: one odd question one normal one...
Originally Posted by bruin_d View Post
The odd one...
Thanks in advance.
#1. Depends on the size of wire you are running....
#2. You can use either carrier bearing on your driveshaft, you just have to change the frame mounting bracket.
Hart_Rod is offline   Reply With Quote
Old 07-21-2011, 05:38 PM   #3
bruin_d
bruin_d's Avatar
1. Haven't bought wires yet, mainly want firewall clean. I was thinking about putting it on the core support somewhere but am worried it might be too long.
2. I have the Porterbuilt cross member that is already drilled for the horseshoe style. Just wondering if there is some kind of adapter plate because I saw a cool billet pedestal style one.
Old 07-21-2011, 05:49 PM   #4
Hart_Rod
Hart_Rod's Avatar
If you use 8 gauge you should be fine. Make sure you use a fuse. Can't you just drill 2 new holes for the pedestal type?
Old 07-21-2011, 05:53 PM   #5
bruin_d
bruin_d's Avatar
A fuse? I'm talking about the wire from the center of the distributer to the coil.
I'll probably just drill a couple holes. Shouldn't be too difficult.
Old 07-21-2011, 06:45 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Run an HEI and forget the coil wire.It'll clean up your engine bay even more than the core support mounting.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-21-2011, 06:55 PM   #7
bruin_d
bruin_d's Avatar
Im pretty sure a HEI won't fit for my setup. Maybe one of the small Mallory ones but I'm not even sure about that. I have the pro-billet, mechanical advance one because I think it the smallest one out there. I could be wrong though, its happened once.
Old 07-21-2011, 06:56 PM   #8
bruin_d
bruin_d's Avatar
A buddy of mine just shared this with me...
a coil will keep charging to a higher and higher Kv till it can over come whatever the total resistance is....(so there is no voltage drop)
when volts goes up...amps goes down so the actual spark "kernel" will be a tiny tiny bit less "robust"....
I'm 95%+ sure you will not have any problems or performance loss...use a good quality spiral wound wire of about 1,000ohms per ft or less
if you do detect a misfire.....close the plug gap by just .001 (ex:.045 to .044 would be from about 18Kv down to 17Kv typically).... so the coil will have to build to a lot less Kv with less gap... than.... the longer higher resistance coil wire added
Old 07-21-2011, 07:15 PM   #9
JCD
JCD's Avatar
I'll take a stab at question 2..
Making an adapter plate is fairly easy..
You already have the hole pattern for the horseshoe type, and if you purchase the billet one, you'll have that too.
Keep the plate thin enough to retain the stance of the driveshaft, and thick enough to take the load.. 1/4" plate aluminum would do, and is easily cut and tapped.
(Steel would be better, and you can go slightly thinner, but you still need it thick enough to retain several threads of a bolt)
A note on the aluminum, go to a metal supply company and ask for either 2024, or 7075.. these are both aircraft grades of aluminum and will take a lot of punishment.
A few careful measurements and it'll work fine..
I've made several similar custom pieces over the years in the machine shop, and this should be a relatively easy piece.
J.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
