04-05-2003, 03:49 PM | #1 |
L.E.D. Freak
Early Classic Super Track bar problems? Pictures needed
I just finished tearing down my rear suspension and this bracket for the Super Trakc bar isn't bolting up. It's hitting on the trailing arm. The holes in the u-bolt won't line up. ???? Any ideas? Anyone have pictures of the stock kit bolted up?
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
04-05-2003, 03:55 PM | #2 |
Member since 2000
stock kit or the ECE kit?
04-05-2003, 07:03 PM | #3 |
Carolina Classic Trucks
I may have some pic of the ECE super trac bar here:
http://photos.yahoo.com/bc/srcjeeper...c=ph%26.view=t Mine went on with no problems. Look at pic DSCN0458. It shows it bolted up at the passenger side trailing arm.
04-06-2003, 04:02 PM | #4 |
Progress = 0%
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
04-07-2003, 11:23 AM | #5 |
L.E.D. Freak
Ok sorry been busy. The right side bracket finally went on. No problem. The bar really needs to be in the top hole. But it hits the frame in that hole. New exhaust going to be tricky.
04-07-2003, 01:56 PM | #6 |
Progress = 0%
Why does it NEED to be in the top hole?
04-07-2003, 03:54 PM | #7 |
Almost Satisfied
I'm not sure either but that is where mine fit the best (angle) and I noticed an ECE set up in a mag and they used the top hole.
I'll use either hole personally
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
04-07-2003, 03:57 PM | #8 |
Member since 2000
lol i think the bottom hole is for stock hieght to 4 inch drop. the top hole is for anything lowered more then 4 inches. I think that how it go's.
edit: 5inch drop top hole 6 inch drop bottom.......that what ece said Last edited by Alexis; 04-07-2003 at 04:54 PM. |
04-07-2003, 06:50 PM | #9 |
Progress = 0%
Yeah, I guess it could perform kind of $hitty if you put it in the hole that it wasn't designed to fit into
04-09-2003, 02:18 PM | #10 |
Reumster, why would your bracket not work? Mine was so simple my 6 year old could have done it. It fits between the trailing arm and axle saddle, just like in the picture in their instructions. The u-bolt drops down thru everything and holds it in place. Stan at ECE said to use the low hole on my 70 because I bought the 6" rear coils. How low did you drop your Blazer?
04-10-2003, 09:42 PM | #11 |
L.E.D. Freak
It's ok now. Fit fine. I was tired and a little tuned up at the time I guess! LOL
It's perfect I love the whole kit. I really think the shock relocator did alot of good on the handling. And I notice the difference in rear end movement from max ride height to aired out.
