![]() Join Date: Feb 2010
5 speed Manual transmission
Hello all, I'm looking to put in a 5 speed manual into my '70 and was looking for something a bit stronger than the T5 from an S10.
What i would really like is what I had in my '94 Z-71, with the 3.73 gears, it had great range in first gear, and cruised well in 5th. Anyone know what model transmission that is, or have any other suggestions? Thanks! Shawn |
Re: 5 speed Manual transmission
Sounds like a nv4500 tranny. Here's a post from stovebolt all about T5 or nv4500 swaps.
Lots of links there too. http://www.stovebolt.com/ubbthreads/...937#Post761937 |
Thanks for the response, and I did a little research... It looks like the NV4500 aka MT8 and MW3 was used in the 3/4 and 1 ton trucks. The one I has was in a 1/2 ton K1500 and didn't have the super low 'granny' first gear.
Does that sound right? |
Ok, looks like I had the NV3500 which was the medium duty 5 speed used in a whole bunch of things.
Anyone swap in a NV3500 and can show where the shifter ends up in the cab? Thanks! |
#5 | |
#6 | |
If you want to put a T-56 behind an old school sbc you'll need a trans from an LT-1 car. The GTO was an LS1 and has a different bell housing and clutch setup. You might look into using the GTO shifter, however, because it moves the shifter position forward a few inches vs. the original LT-1 shifter. You will also need a hydraulic clutch assembly with a push type slave. The stock slave can be modified to fit an aftermarket master, the master from the f-body has an angled mounting plate on it due to the floor boards and would be hard to mount in our trucks. I put a T-56 into my 96 Impala SS, so if you do go that route shoot me a PM and I can send you some pics and info of what is involved with a T-56 swap. I've even been looking into putting one into my 96 ext cab Chevy when the 4L60E takes a crap on me. I have no info about the NV3500 though. |
oohh very good information.
If you want something "a bit stronger" then an S-10 T-5 you can use a Camero T-5 & put a S-10 tail houseing on it or use bucket seats. It is the World Class model & is a little stouter then the NWC from the S-10. I have run T-5s behind 350 V-8s. As long sas you don't hot-rod it it will hold up.
The Older Generation
A couple of threads on the subject.... http://67-72chevytrucks.com/vboard/s...d.php?t=417079 http://67-72chevytrucks.com/vboard/s...d.php?t=475370 LockDoc
Eat, Sleep, Drive a Chevy
Looks like some good info for me too. I have an LT-1 and a 6 speed I pulled from a Z-28 a while back, I have been thinking about dropping it in a 67-72 at some point.
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
Pretty sure most of these swaps require a different clutch setup than is on our trucks, something to keep in mind.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Thanks for all the replies guys... but after even more research, I've found that I've been chasing my tail because this transmission will be going behind an LS 5.3... so the older ones won't work. I'll have to use a newer car trans now I suppose.
LockDoc, thanks for the links... I liked seeing the alternate transmission swaps from the supra and Jeeps. Last edited by Zeke's Garage; 07-22-2011 at 10:23 PM. Reason: Adding thanks... |
#13 |
Laid Back
![]() Join Date: Apr 2010
Use the t56
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
#14 | |
LockDoc
#15 | |
Slap a junkyard turbo on that bad boy and you'll have a screamer of a truck. FYI if you do go with the T-56 I would go with a 4.10 gear in the rear. I had 3.73's in my impala (4600 pounds with me in it) and 6th gear was useless at anything under 85. I've not got 4.56's in it and they are a little too steep. I can take off from a dead stop in 5th gear with my built stroker in front of the trans. |
#16 |
Ok, time to start sourcing GTO transmissions... shoot, might as well get the 6.0 that's on the other end while I'm at it...
Thanks for the help guys! |
#17 |
#18 |
They put a 5 speed behind the The 4.8s all the way up to 07 classic body style. Also, the bolt patern is the same as a 350 so, you could still use the NV3500 if you wanted. As long as you get the clutch stuff set up correct. I plan on using a 5 speed behind my 5.3 as well. I know the trannies they put behind the 4.8s hold up to quite a bit of power. Don't know the part number though.
Posted via Mobile Device |
#19 |
I have had real good luck with a Tremac TKO-600, you should only have to change the clutch disc to a fine spline and move the rear crossmember.
It will hold up to 600HP and has a real good 1st and even a better 5th !! Start saving your lunch money!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
