Old 07-22-2011, 01:48 PM   #1
BarnabyHooge
Bench Swap
I've got a line on a nicer bench seat for a pretty good price but I'm a little concerned about the ins and outs of swapping them out.
I assume it's 8-10 bolts easily accessed from under the cab, but I want to make sure before I commit. My bench has me fallen off towards the door.
I guess I"m also assuming a 67 will fit in a 71.
Thoughts?
BarnabyHooge is offline   Reply With Quote
Old 07-22-2011, 02:01 PM   #2
dmack91
dmack91's Avatar
Re: Bench Swap
I think the mounts are the same (upholstery may be a bit different).
There are two bolts front and back on each side, and they are all accessible from inside the cab. The nuts are welded to the mounts under the cab, so you can do it easily by yourself.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 07-22-2011, 02:04 PM   #3
BarnabyHooge
Re: Bench Swap
Great.
The bench has been redone, so that's not an issue. Sounds like I should be able to knock it out fairly quickly.
Much appreciated.
