Old 07-22-2011, 02:51 PM   #1
mailman
mailman's Avatar
Leaking Summit fuel cell
Has anyone had a leak around the white washers in the sump part,and how do you fix it?
mailman is offline   Reply With Quote
Old 07-22-2011, 04:50 PM   #2
john
member #16
john's Avatar
Re: Leaking Summit fuel cell
Is that an "o" ring type fitting? The fitting with the line hooked up appears to be a different type seal.
john is offline   Reply With Quote
Old 07-22-2011, 04:58 PM   #3
mailman
mailman's Avatar
Yes it is.I guest I will have to put my hand inside the tank and try to tighten it up.
Old 07-22-2011, 05:14 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
how close is that hard line to the frame might rub thur on vibration just sayin'
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
