Old 07-22-2011, 03:15 PM   #1
67chevy77
67chevy77's Avatar
4l60e problems
I have a 99 gmc z71. I can drive the truck with no problems for 50 miles or more and the all of a sudden when I come to a stop it shifts real hard like it has a shift kit. It only does it every now and then so it doesnt happen often. And after it starts messing up I can I turn the truck off and go start it back it shifts fine. Anyone know what it with might be? Im thinking its the valve body or a sensor making it do that.
Justin
1977 chevrolet rebuilt 350 9 inches of lift with 40s 4.56 gears. Work in progress.
1967 4x4 -sold-
1988 reg cab short bed 4x4 -sold-
1999 GMC extended cab short bed new body style Lifted on 33s.
67chevy77 is offline   Reply With Quote
Old 07-22-2011, 03:55 PM   #2
clinebarger
Re: 4l60e problems
Have it scanned for PCS (pressure control solenoid) codes.
clinebarger is offline   Reply With Quote
Old 07-22-2011, 04:43 PM   #3
67chevy77
67chevy77's Avatar
Re: 4l60e problems
Ill have to check that. I hooked up a scanner to it a while back and it wasnt throwing any codes.
Justin
1967 4x4 -sold-
Old 07-22-2011, 11:46 PM   #4
clinebarger
Re: 4l60e problems
Check the transmission fluid level, What scan tool was used? Not all "generic OBD II" scan tools read "manufacturer specific codes"
Old 07-25-2011, 06:38 PM   #5
67chevy77
67chevy77's Avatar
Re: 4l60e problems
Fluid level is fine. I used the "red brick" snap on scanner.
Justin
1967 4x4 -sold-
Old 07-25-2011, 08:49 PM   #6
clinebarger
Re: 4l60e problems
A snap-on MT2500 will do the job. There has to be a code or codes now, Cycling the key....Then normal operation is a dead give away.
Old 07-25-2011, 09:52 PM   #7
67chevy77
67chevy77's Avatar
Re: 4l60e problems
Ill put the scanner on it again but I know last time it didnt have any codes. Nothing in the history either if I remember right.
Justin
1967 4x4 -sold-
Old 08-03-2011, 11:02 AM   #8
67chevy77
67chevy77's Avatar
Re: 4l60e problems
Still no codes. I just put the scanner on it and and normal driving the pcs duty % was anywhere from 47 to 52. But I couldn't get it to mess up to see if any of that changed.
Justin
1967 4x4 -sold-
Old 08-04-2011, 07:04 PM   #9
clinebarger
Re: 4l60e problems
This is going to be interesting. I use my Tech II so much I forget what exactly the MT2500 shows for data,
Heres a test using Actual Amps vs Reference Amps on the pressure control solenoid....
1. Test drive the vehicle. During the harsh shifting issue, monitor the "PC Sol. Actual Current" vs the "PC Sol Ref. Current". The values should match.
2. If the amperage is always low (less than 0.50 amps), recheck the sensor input to the PCM.
3. If the amperage is normal or high during the shifts, perform the line pressure test.
4. If the line pressure is high vs. the amperage, install an ammeter in the circuit to confirm the "PC Sol Ref. Current" is being put out by the PCM. Using an ammeter installed on the Red/Black wire at pin 6 on the Red PCM connector.
5. If the ammeter shows no or lower than expected current, replace the PCM.
6. If the ammeter matches the "PC Sol Ref. Current" check the Pressure Control Solenoid (PCS) and or valve in the transmission.
Or put a PCS solenoid in it & see what happens.
