07-22-2011, 06:07 PM | #1 |
Where a good source of wiring connectors?
Anyone have a source for wiring supplies? Specifically, different plugs like the ones that let you disconnect sections of the wiring. I'm using an EZ Wire 21 circuit harness and I want to make most everything dis-connectable. I need one for the steering column and I also want one for the instrument panel, headlights, and just about everything else.
07-23-2011, 07:06 AM | #2 |
Hollister Road Co.
Re: Where a good source of wiring connectors?
Depending on what you need
eficonnection.com pigtails and EFI connectors waytekwire.com good source for weatherpack and packard but has minimum order quantities. repairconnector.com good for pigtails Mouser.com is good but you really need to know the part number to get through the site in any reasonable amount of time. |
07-23-2011, 08:40 AM | #3 |
Spanked once
I looked quite a bit to get the goods to do my 71 which is non stock. American autowire is where I'm getting all my connectors ,relays and terminal strips etc. The wire I need will come from Jegs.
The ole 350 budget build. |
07-23-2011, 12:59 PM | #4 |
my approch is a bit different, I usually get the weather pack connectors from a wrecker (which are usually free) and get new male/ female terminals from an electronics store, dirt cheap for a box of 100 . where I live there is a place called Quale electronics where you can buy just about anything for electronics, I'm sure there is an equivilent near you. Then again I'm cheap and hate waiting for stuff on mail order
07-23-2011, 06:57 PM | #5 |
07-23-2011, 08:06 PM | #6 |
07-24-2011, 09:16 AM | #7 | |
Spanked once
