Old 07-22-2011, 07:06 PM   #1
coops714x4
coops714x4's Avatar
Steering column bearings
OK guys I need some info and help WHERE can I get the bearings for a stock steering column or a rebuild kit I asked at my local O'reallys and they said I would have to go to a chevy dealer ???? I looked at LMC and no such critter so if anyone knows where I can get the stuff to fix my column I would be very grateful for the info its a 71 K20 4speed its a straight plain column.
the bottom bearing went out and the top one has got play in it
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
Old 07-22-2011, 07:32 PM   #2
1972RedNeck
1972RedNeck's Avatar
Re: Steering column bearings
I just got my top one from LMC. The reson I got one was because I thought it had too much play. The new one has just as much.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-22-2011, 07:45 PM   #3
john
member #16
john's Avatar
heres some. See Wes
http://www.classicheartbeat.com/steering_column.htm
john is offline   Reply With Quote
Old 07-22-2011, 07:57 PM   #4
sjarrett71
sjarrett71's Avatar
Several board vendors sell them
-Scott-
sjarrett71 is offline   Reply With Quote
Old 07-23-2011, 08:18 AM   #5
lt704
hello 1972 redneck, i had the same problem as you, bought one from LMC, same problem. After the guys and i looked at it for a few hours we found out what the play in the steering wheel shaft was. when i switched out to a 1990's s-10 steering wheel i also used a 1994 cancellation cam as well. our 67-72 cacellation cams are bevelled on the bottom and the 94's cam is flstraight flushed at the bottom. put my old cam on and no play. it is amazing how something so small can make you crazy....Russ
1968 Chevrolet C-10 2 wheel drive
Lil' Red
In life always try to make a difference
lt704 is offline   Reply With Quote
Old 07-24-2011, 03:58 PM   #6
coops714x4
coops714x4's Avatar
man those things are expensive never thought the bottom bearing would be 40 bucks the top isn't too bad its only 20 still 60 bucks for those two bearing JEEEZZZ
Old 07-24-2011, 06:18 PM   #7
Wrenchbender Ret
The shaft is supposed to float inside the lower brg. Then the spring takes up any slack. After time the shaft gets stuck in the sleeve & thats when you get looseness when you change anything. The lower brg is in a horrible invironment.
Wrenchbender Ret is offline   Reply With Quote
Old 07-30-2011, 12:39 PM   #8
coops714x4
coops714x4's Avatar
Ok guys I got my bearings any tips on changing them ??
