Old 07-22-2011, 07:54 PM   #1
bmnk
bmnk's Avatar
'50 3600 Just a couple questions...
A few days ago I was offered a deal I couldn't pass up on a 1950 3/4 ton truck, that is all original. I think I've decided to keep it stock because it's very solid and it runs, but I am thinking I want to do some minor upgrades like replace the brake lines and add a dual master cylinder, and replace the rear axle so I can maybe get above 50mph without having to be going downhill with the wind to my back.
My question is does anyone have any recommendation to the best fitting rear axles for the 3/4 ton trucks. I would like to retain the 8 lug wheels. Or can I find new gear ratio to replace inside the pumpkin? I know my '52 has a late 70's Camaro rear axle, but I really want to stay away from the 5 lugs, and keep the truck feel about this one.
Also I'm thinking of replacing the wire harness, as it's still the original cloth covered wires, and they are starting to show there age....should I go ahead and change to 12 volt system while I'm doing the wiring anyway, or will sticking with the 6 volt be just fine.
bmnk is offline   Reply With Quote
Old 07-22-2011, 08:28 PM   #2
BlueJeep
BlueJeep's Avatar
Re: '50 3600 Just a couple questions...
A cab and chassis (dually with no pickup box) 14 bolt is 63" wide and can be found in 73-90's trucks. 60's Fords had a 63ish wide dana 60. Measure how wide your existing rear is and go from there.
A bolt in option to get 4.10's (better than your 4.56's but not as good as 3.73's) would be to use the center section out of a 67-72 3/4 ton....you can find the details of this with some searching.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
